Electronics Forums
Electronics Forums > Newsgroups > Electronics Newsgroups > Electrical Engineering > Re: The CFA de-bagged (Was: Re: First "Del" and now "D'Alembertian"!)
Reply
Thread Tools Display Modes
John Smith
Guest
Posts: n/a
      07-22-2005, 08:53 PM
I have always used the CFA as a mobile antenna!
Get with the program people, you will be hard pressed to find a better
antenna for this purpose!
As a shack antenna, it sucks!
However, what other antenna can you chuck a motor into, slap a
steering wheel and horn on and drive?
You guys are all wet, as usual... <satisfied-smirk>
John
"Polymath" <(E-Mail Removed)> wrote in message
news:42cf5a7c$(E-Mail Removed)...
> Actually, just did a quick webbing and found enough to
> realise that the claims are founded upon feet of clay.....
> 1. You do not separately excite the E and H fields because
> if you excite an E field, you get a corresponding H field, and
> vice-versa,
> even if it is your intention to excite separately.
> 2. The differential forms of Maxwell describe the fields at _EVERY_
> infinitesimal point and there is no way that the attempt to excite
> two
> separate fields from two separate mechanical contrivances will
> result
> in registration at every single point. Indeed, it is doubtful that
> registration
> will be achieved at all at any infinitesimal point. In any case, as
> in (1) above,
> your E field will have its H, and your H field will have its E field
> already.
> 3. In the accepted equations describing the generated field,
> radiation comes only
> from accelerating charges. Thus the capacitive elements of the CFA
> will
> create the near field (decaying as 1/(r^2)) but not any radiated
> field
> (decaying as 1/r). I wonder if the measurements resulting in the
> claims
> for the CFA were made in the near field?
> I wonder if the whole thing is intended as an elaborate hoax, and
> that the
> authors, in their original paper in Wireless World, relied on the
> fact that
> most readers' eyes would glaze over when faced with the maths of
> vector
> fields? (Remember, that in this NG we've had someone who boasts of
> two degrees, one in maths and the other in electronics, stating that
> e^(-jwt)
> is a function that decreases with increasing time, thus indicating
> that the
> awarding of a degree together with the professing of mathematical
> equations is no guarantee of competence!)
> I suggest
> http://farside.ph.utexas.edu/teachin...es/node53.html etc
> as a good revising/learning/debunking cookbook. (Don't start from
> node 53!)
> news:(E-Mail Removed)...
>> I've just about got enough elec-and-mag theory to be
>> able to understand the claims made for the GM3HAT
>> CFA; any pointers to the patent claims?
NunYa Bidness
Guest
Posts: n/a
      07-23-2005, 09:14 AM
On Fri, 22 Jul 2005 13:53:42 -0700, "John Smith"
<(E-Mail Removed)> Gave us:
I suppose then that you consider yourself to be firmly grounded in
reality.
John Smith
Guest
Posts: n/a
      07-23-2005, 12:24 PM
Firmly grounded?
Actually, when I am finished installing the mercedes turbo-jet engine
in the CFA, I plan on flying it!--well, after installing the carbon
graphite wings...
John
"NunYa Bidness" <(E-Mail Removed)> wrote in message
> reality.
John Smith
Guest
Posts: n/a
      07-23-2005, 06:27 PM
OK.
It is like this, years ago, in the 1980's, when telnet was still being
used on the predecessors of newsgroups, there was no way to logically
organize "posts."
Still, into the 90's, most all "news clients" lacked any meaningful
way to organize threads and/or posts.
At the end of the 90's a few news clients managed to "get-it-together"
and organize threads and posts with pretty good results.
Now it is 2005. Windows xp comes with a completely functional news
reader which holds threads and posts in perfect order--no longer do I
have to have the text being responded to placed above the text which
is being issued in response. Still, many ancient news readers are in
use, and the users have not bothered to upgrade them. Also, many are
reading these posts from webpages...
That is all their responsibility now, if they are unwilling or unable
to setup a decent news reader and come up to speed, that is their
problem--there is NO longer a real need to bottom post, indeed, it
only slows down ones interaction with the group and places an
un-necessary burden to be cutting and pruning text...
.... the etiquette and use manuals of usenet need upgrading ...
I will be top posting...
end of story...
John
> On Sat, 23 Jul 2005 05:24:20 -0700, "John Smith"
>>Firmly grounded?
> Yes. You made an all wet joke. I made an electrical joke that you
> should have gotten.
>>engine
>>graphite wings...
> Perhaps you did.
> Top posting is very bad.
John Smith
Guest
Posts: n/a
      07-23-2005, 06:30 PM
oh yeah...
It is a half-wave CFA. No ground plane/counterpoise is needed...
I live in calif, who worries about lightning here...
<grin>
John
>>Firmly grounded?
> should have gotten.
>>engine
>>graphite wings...
> Perhaps you did.
Walt Davidson
Guest
Posts: n/a
      07-23-2005, 06:59 PM
On Sat, 23 Jul 2005 11:27:56 -0700, "John Smith"
And I will be killfiling you, like all other top-posting fools ....
because top-posters invariably have nothing to say that is worth
reading.
Goodbye.
Walt Davidson Email: g3nyy @despammed.com
John Smith
Guest
Posts: n/a
      07-23-2005, 07:35 PM
Ohh gee:
Killfiled
What if I told ya to shove the whole killfile up yer bum, would that
make it ok?
ROFLOL
"Walt Davidson" <(E-Mail Removed)> wrote in message
> reading.
> Goodbye.
> @despammed.com
Fred W4JLE
Guest
Posts: n/a
      07-23-2005, 07:36 PM
And I thought you Brits were supposed to be so tolerant of diversity... Here
I find you making broad generalizations based on the position of words on a
screen. One can only assume you are a narrow minded word position bigot! You
will be doomed to hell for your non politically correct speech, possibly
even jailed for hate speech...
> reading.
> Goodbye.
John Smith
Guest
Posts: n/a
      07-23-2005, 07:38 PM
Nunya:
Look, I am not even going to take the time to read all that crap.
If you want to say something to me, don't intermingle it together with
all the text I just wrote, I remember what I wrote, just write a damn
reply...
However, I think the jest (haha) of your text attempts to make me
format my text for your text reader--get a clue buddy, if you want to
read it, you format it!!!
Killfile me otherwise, I will be crushed, but I will get over it...
John
>>OK.
>>being
>>logically
>>organize "posts."
> I think that you have history problems.
> I know that you have history problems.
>>"get-it-together"
> I think that you have a problem with opinion over fact as well.
>>I
> Guess what? You are not the only person that is reading a thread,
> and those that are are not all on windows xp. Outlook express is a
> dog. It has also been around way longer than XP has.
> You assume way too much, and those assumptions have ALWAYS screwed
> up someone that doesn't live in your perfect world of "organized
> articles".
> There are protocols in place for this very reason, and all the
> logic
> you throw at it doesn't change that fact.
> That has not a thing to do with the problem. Your opinion about
> what is or is not a good news reader has NO bearing on proper
> protocol. The problem is that posters such as yourself ASSUME way
> too
> much, and no one else in the world needs to cater to YOUR idea of
> what
> is modern. Again, Outhouse Express is a total dog. That opinion is
> held in the eyes of many.
>> Also, many are
> Another tragic screw up. Especially when they reply from web
> access.
>>unable
>>problem
> I find that you are unwilling or to stupid to understand the fact
> that not everyone even reads news the way you do. I happen to read
> posts chronologically, despite my reader's capacity to show threads
> in
> a grouped manner. That is a choice. Deciding to throw out the
> standard accepted decades long protocols based on your opinion of
> what
> is or is not modern is just plain arrogant ignorance.
> You are NOT anyone that can declare such a thing.
> Your brain needs to conform. That is the only upgrade required.
> You claim others haven't gotten up to your modern standard and that
> is where YOU are wrong. Despite any news reader clients capacity
> for
> sorting articles, it is ALWAYS proper to make the post in a manner
> such that a person reading ONLY that post can garner the gist of the
> article WITHOUT any requisite to read additional articles. THAT is
> the whole point. Not only that, but you idiots invariably quote the
> entire article to which you respond, which is another mistake.
> You are stupid... You utilization of Outhouse Express proves that
> beyond a doubt. I am surprised that you aren't posting in HTML and
> defending that as well. What a total ditz you must be.
>>end of story...
> End of fact finding and declaring mission.
John Smith
Guest
Posts: n/a
      07-23-2005, 08:06 PM
Fred:
I hate to admit it, but that made me damn near split a gut! <lol>
John
"Fred W4JLE" <(E-Mail Removed)> wrote in message
news:efc12$42e29c3d$471c636a$(E-Mail Removed)...
> diversity... Here
> words on a
> bigot! You
> possibly
>> reading.
>> Goodbye.
>> @despammed.com
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
Re: NXP claims world's first sub 1 milliOhm MOSFET in a Power S08 ...Jul 8, 2009 ... NXP Semiconductors has unveiled the world's first n-channel sub 1 milliOhm 25 V MOSFET, PSMN1R2-25YL, and is claiming the lowest ever RDSon ... Archimedes' Lever Electronic Basics 4 09-30-2009 11:12 PM
Re: The CFA de-bagged (Was: Re: First "Del" and now "D'Alembertian"!) Reg Edwards Electrical Engineering 39 07-23-2005 03:09 PM
Re: The CFA de-bagged (Was: Re: First "Del" and now "D'Alembertian"!) Spike Electrical Engineering 46 07-23-2005 09:12 AM
Re: The CFA de-bagged (Was: Re: First "Del" and now "D'Alembertian"!) Frank Electrical Engineering 0 07-10-2005 03:46 AM
Re: The CFA de-bagged (Was: Re: First "Del" and now "D'Alembertian"!) Spike Electrical Engineering 3 07-09-2005 11:45 AM
