(E-Mail Removed) schrieb:
> Hi All, I have a question which i couldn't find the solution. And hope
> someone could give me a shout here.
> I am designing medical equipment which needs a lot of coaxial cables.
> And, i want to put all those cables (8) together into a bigger pipe.
> what is name or material of this pipe? I saw some company used it, and
> it can wrap all cables very tightly and closely, and look like
> heat-shrink tube. Thanks, Ethan
Hello,
if you bundle a lot of coaxial cables very tightly and closely and when
these bundle is bend in use a several times, you may get problems with
the cables. The bending of the bundle will stretch and jolt the coaxials
cables, this may alter the impedance of the cables and cause signal
reflections.
Bye
