Electronics Forums
Electronics Forums > Newsgroups > Electronics Newsgroups > Security Alarms > Re: Alarm System and Home Automation FAQ - Cutting Holes in the Wall With No Mess
Reply
Thread Tools Display Modes
Aegis
Guest
Posts: n/a
      01-16-2004, 02:59 AM
"Robert L. Bass" <(E-Mail Removed)> wrote in message
news:x6udnbBom_QM75vdRVn-(E-Mail Removed)...
> Q. How do I cut holes in sheet rock or plaster walls / ceilings without
> making a big mess?
> A. Paul Sanchez wrote in a Usenet news group Comp.Home.Automation:
> What we've been doing for years is take a clear plastic bag and
> painter's-tape it over the spot you plan to cut your gem box or whatever -
> that is tape the bag all around its opening. Then, take a Dremel tool with
a
> zip bit in it and poke it through the bag and cut your hole. Before you
> remove the bag, wipe all around the hole with the bag. No muss no fuss.
> Works great for retrofitting recessed lighting too. Our customers are
amazed
> that we can do a whole room without making any mess at all.
We had to use something quite similar to that in the clean room fabs at a
Sony semiconductor manufacturing plant. Had the bunny suits on too!
Marc
Guest
Posts: n/a
      01-16-2004, 09:19 PM
I just did work in a synagogue where it used to be a house and they
converted... they had a drop ceiling and when i moved a tile, the old
celieng that was plaster broke, a big chunk full on my head and made dust
everywhere... my little hand held vacuum couldnt handle all the mess today,
had to go get the real vacuum .. nothing around that mess
"Aegis" <(E-Mail Removed)> wrote in message
news:jkJNb.8182$(E-Mail Removed) m...
>> making a big mess?
>> whatever -
>> with
> a
> amazed
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
Best alarm system for home automation.... petem Security Alarms 8 02-27-2004 12:41 AM
Re: Alarm System and Home Automation FAQ - Garage Door (part 2) frank roarty Security Alarms 0 01-19-2004 08:44 PM
Re: Alarm System and Home Automation FAQ - Magnetic Contacts spike Security Alarms 0 01-15-2004 09:51 PM
Re: Alarm System and Home Automation FAQ - Cutting Holes in the Wall With No Mess spike Security Alarms 0 01-15-2004 09:51 PM
Re: Alarm System & Home Automation FAQ PublicGadfly Security Alarms 3 07-30-2003 03:30 AM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93
