Robert L Bass wrote:
> "Jim Rojas" wrote:
>> Tower Security wrote:
>>>> ...you should be able to do it
>>>> exactly the same way as adding an LED that is on when armed, just
>>>> powering a relay to hold the circuit open instead of an LED.
>>> Precisely...which still means programming sections 79 and 80 correctly
>>> and I'm hoping that someone has done this previously and can provide
>>> some assistance...
>>> Doing this on a DSC is as simple as programming a 17 in section
>>> 009...surely someone can translate this into Ademcobabble?!?...
>> I don't even know if you can do it through the keypad on an Ademco
>> Vista 15P...I usually do it through the software. You select a relay
>> and output and choose which zones trigger the output, and for whatever
>> condition or reason. DSC is very simplistic. Ademco gets into more
>> details and options when it comes to relay outputs.
> I hate programming Hoineywell panels, but here's the routine. I *think*
> this is correct. :^)
> Enter program mode by powering down then back up
> and pressing the *+# simultaneously within 50 seconds
> of power up, or enter the Installer code:
> (4112) + 8 + 0 + 0
> Screen displays:
> "INSTALLER CODE 20"
> Press *80
> Screen displays:
> "Output Funct #" 01
> Press 01*
> Screen displays:
> "01 A E Trig
> ?00 0 0 - ZL =00"
> Press *
> Screen Displays:
> "01 Activated By: Delete 0"
> Press 2
> Screen will display:
> "01 Enter Zone Type"
> Press 21 = Arming-AWAY
> After this:
> Press *
> Press *
> Screen displays:
> "Output action"
> Press 2 = Close and Stay Closed
> Screen displays:
> "Enter Output No."
> Press 17 = Trigger 1
> or
> 18 = Trigger 2
> Screen displays summery:
> "01 A E Trig
> ?00 0 0 - ZL =00"
> Press *
> Screen displays "Output Funct #"
> Press 00 to quit
> Hope that helps.
Like I said...better off using the software.
Jim Rojas
