Electronics Forums
Electronics Forums > Newsgroups > Electronics Newsgroups > 8bit Microcontrollers > Re: 8051 Compiler
Reply
Thread Tools Display Modes
Re: 8051 Compiler
Tim Daneliuk
Guest
Posts: n/a
      05-13-2009, 08:36 PM
Me wrote:
> I have allways used ASM51 to compile my 8051 .asm code but I find it doesnt
> work on Vista.
> Looking for Assembly compiler/assembler for the 8051 series that works under
> vista.
> I know there are C compilers, but I am looking for .asm
> Thanks in advance
You might try this, running under cygwin on WinDoze. I use cygwin
regularly under XP and it is rock solid. I've not used this compiler,
but it's been around a long time now:
http://sdcc.sourceforge.net/
Tim Daneliuk (E-Mail Removed)
PGP Key: http://www.tundraware.com/PGP/
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
Re: 8051 Compiler WangoTango 8bit Microcontrollers 0 05-13-2009 07:48 PM
Re: Oshon compiler for PIC Fester Addams 8bit Microcontrollers 1 10-06-2004 10:16 AM
Re: PIC CCS compiler Andrew 8bit Microcontrollers 0 09-09-2004 08:33 AM
Re: experience with ccs compiler with pic 18Fxxx martin de lange 8bit Microcontrollers 2 08-14-2003 06:07 AM
Wanted: Keil assembler compiler tools 8051 Fred Rockenberger 8bit Microcontrollers 0 08-08-2003 04:03 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93
