Electronics Forums
Electronics Forums > Newsgroups > Electronics Newsgroups > Electronic Repair > RCA TV/DVD Replacement Board
Reply
Thread Tools Display Modes
Gary
Guest
Posts: n/a
      01-15-2004, 11:44 PM
I have an RCA TV/DVD combo system that was dropped and cracked the main pcb.
There are about 30 runs that are broken. Instead of patching it, I was
wondering if there is a place where I can get a new board from. The DVD is
salvageable and the flat screen tube is good. Just a broke board.
Model: BD20TF10
Chassis: TVD809COMBO
Sofie
Guest
Posts: n/a
      01-16-2004, 12:52 AM
Gary:
Either have the board repaired or junk the set. Replacement board costs
will approach or exceed the cost of a new unit. If you could get a new
board cheaply you will still have to have a tech align the board to the CRT
and yoke.
At the very least you should TAKE it to a repair shop for a repair cost
estimate so you can make an intelligent repair decision with facts instead
of internet or telephone guesses. Depending on the nature and location of
the broken pcb traces the repair may be economical..... TAKE it to a shop.
Best Regards,
Daniel Sofie
Electronics Supply & Repair
"Gary" <(E-Mail Removed)> wrote in message
news:(E-Mail Removed)...
pcb.
is
> Model: BD20TF10
ampdoc
Guest
Posts: n/a
      01-16-2004, 01:03 AM
Just patch the board back together. I have found one of the best materials
to use for jumping small traces is Kynar insulated wire wrap wire, like you
get at radio shack. That stuff is easy to handle, and the heat of the
soldering iron will melt the insulation, so you don't even have to strip it.
Just wipe the insulation back at your connection point with the iron tip,
then solder! with only 30 traces or so broken, it shouldn't take more than
an hour or so to fix.
Jammy Harbin
J & J Electronics, Inc
227 S. 4Th St.
Selmer, TN 38375
731-645-3311
pcb.
is
> Model: BD20TF10
James Sweet
Guest
Posts: n/a
      01-16-2004, 01:36 AM
"ampdoc" <(E-Mail Removed)> wrote in message
news:cCHNb.1964$(E-Mail Removed)...
you
it.
Yeah that's what I do too, but I strip the wire first, keeps the soldering
iron tip from getting so gunked up. Be sure the glue the board first so it
has structural strength.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
0.8mm pitch board to board surface mount connector needed. Please help if you can. kel-fbs Electronic Repair 0 11-18-2006 10:10 PM
Sanyo DP42746 AV board replacement. captainvideo462002@yahoo.com Electronic Repair 2 06-30-2006 08:41 PM
B-Board replacement for a crippled KZ-42TS1 Junius Electronic Repair 1 06-04-2006 11:25 PM
Denon AVR 2400 Power Supply Board Replacement audioluvr@gmail.com Electronic Repair 2 01-28-2005 11:45 AM
WTD:Compaq 21" P110 replacement output driver board .. mc Hobby Electronics 1 03-07-2004 10:54 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93
