Electronics Forums
Electronics Forums > Newsgroups > Electronics Newsgroups > Electronic Repair > RCA service menu.
Reply
Thread Tools Display Modes
RCA service menu.
Dani
Guest
Posts: n/a
      02-05-2007, 04:01 PM
Rear projection T.V., Model # P46721BA chassis # CTC 169PK How do you
get into the convergence service menu, & also, how do you adjust the
horizontal width, & centering?
Can't find anything online, or on RCA site. Thanks, Dani.
dkuhajda@locl.net
Guest
Posts: n/a
      02-05-2007, 11:50 PM
You don't get into the service menu.
Width and centering are analog controls inside the rear of the set.
Make certain that any faults are repaired first and check all
voltages. It is common for the convergence and width to go bad when
the power regulator starts to have problems from either the 15V diode
or many different capacitors in the smps.
It is an analog convergence panel which requires a pattern generator
and every control interacts with other controls. All the convergence
power supply voltages and waveforms must be checked if it has changed
over time before starting to move any controls.
It only takes 3-4 hours on average to totally re-work the registration
and convergence after someone who had no clue what they were doing
messed with all the controls while there was a fault present.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
RCA service menu. Dani Electronic Repair 1 02-21-2007 08:32 PM
TV service menu blackevilweredragon@gmail.com Electronic Repair 2 06-30-2006 04:26 AM
RCA CRT TV Service Menu fenixtx128@gmail.com Electronic Repair 4 02-24-2006 04:09 PM
Panasonic TV Service Menu Bill Bailley Hobby Electronics 3 05-17-2005 07:26 AM
Sanyo service menu Keith Electronic Repair 6 01-08-2004 05:47 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93
