I have the same unit. Mine was the main power supply (SMPS) with a
blown HOT (horizontal output transistor,) shorted HV Splitter (the
thing behind in the front panel that has all the big red wires going to
it,) and some bad caps in the SMPS that were causing the voltage to
ride too high in the first place.
I bought the repair kit from
http://www.tritronicsinc.com and got it
going. Unfortunately, I messed up the convergence and it is a real
pain to readjust and I gave up on it for a while. I'm spoiled by the
newer sets where you do it from the remote in service mode.
Sounds like you have other problems to boot and I don't know about
those factors. You can
buy a service manual and try and track the problem down but the time
may not be worth it.
Good Luck
jsandlin wrote:
> I got a big screen tv from a family member. They said that it would
> work but it would lose color and go to black and white sometimes. I
> plugged it in when i got it home and the power light came on and
> blinked a couple of times, then went out. I then tried it again and the
> same thing happened. It done this about 5 times before it stopped and i
> smelled that familiar electronic burning smell.
> I opened the back up and could see that a resistor was burnt on the
> right side board, but that can't be the main problem. I can hear a
> clicking sound on the power supply board when i plug the power cable
> in. It only happens for a few seconds and then quits until i unplug the
> power cord, wait a minute or so, and plug it back in. Is this a rely
> clicking like that?
> Please help. I would like to get this going.
> Thanks
> Jason
