Electronics Forums
Electronics Forums > Newsgroups > Electronics Newsgroups > Electronic Repair > RCA G35302wk - power switch broken - need repair advice
Reply
Thread Tools Display Modes
Robert Gray
Guest
Posts: n/a
      01-04-2007, 03:34 AM
I just started looking at a an RCA TV that would not power up. I read a
troubleshooting summary somewhere recently that described how someone had
found their power switch was broken. I managed to remove some screws so that
I could pull the face plate forward. And I can now see that the power switch
does indeed look like it is broken and no longer physically reaching the
circuit board. So I would like to replace that part. (Or I may try to repair
it - as was described in the link I read, if I can find it again.) So I have
two questions.I could use help with:
1. I can only pull out the top part of the frame. The bottom seems to be
stuck - even though I have removed the same screws on the bottm. It's almost
as if it is connected to the speaker cloth of the speaker board below. I
didn't see any other obvious screws and figured it was best to ask others
for help before I try to 'force' it free. I will need to get it free in
order to disassemble the power switch.
And 2, where can I order the switch - if I can not find the repair advice?
(something about soldering an extension to the switch where it broke.
thx - robert
radiotech@corrwireless.com
Guest
Posts: n/a
      01-04-2007, 02:01 PM
> thx - robert
Does the set operate with the remote? If so the most economical repair
would be to simpally use the remote. If this is unacceptable send me
the Chassis # along with mo# & iI will attempt to locate a part # for
you (E-Mail Removed)
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
Re: RCA g35302wk Picutre collapse dBc Electronic Repair 0 05-14-2008 05:11 AM
Re: RCA g35302wk Picutre collapse propman Electronic Repair 0 05-12-2008 07:39 PM
Re: RCA g35302wk Picutre collapse James Sweet Electronic Repair 1 05-12-2008 07:11 PM
RCA g35302wk Manual Guasano Electronic Repair 1 03-07-2006 01:15 AM
FA: Mitsubishi hs-u70 SVHS vhs VCR (Broken needs repair)/ ToshibaSatellite 2535CDS Laptop (broken screen) robotron -X- Electronic Repair 0 08-05-2004 07:17 PM
