Electronics Forums
Electronics Forums > Newsgroups > Electronics Newsgroups > Electronic Basics > A Question About The Legendary Confuser, The Radio
Reply
Thread Tools Display Modes
Pete Holland Jr.
Guest
Posts: n/a
      04-12-2006, 03:02 AM
Hey, everybody!
I got busy and had to take a break from playing with electronics, but I'm
caught up and looking to continue the learning process. A thought struck
me today while examining a radio circuit, and I wanted to see if I'm on the
right track.
To show the page of music I'm on: a while ago, I posted a question asking
where the ground on a transistor radio was because a ground was necessary
and I couldn't figure out how they did it. I was informed it was part of
the antenna. The kit has you start by building a crystal radio first, then
a transistor radio. It says a transistor can amplify. So far, so good.
While examining the circuitry and the schematic, a thought hit me. As I
traced the flow of the current, it appeared that the battery current flowed
along the transistor, but not into the antenna coil. It looks to me like
the transistor radio is actually two more or less independent circuits, and
the transistors act as a bridge. The first circuit is a crystal radio.
Where it joins the transistors, the signal amplifies and gets boosted by
the battery, and that's the second circuit that enables you to hear it,
control the volume, etc.
Am I right about the two circuits working together, or am I missing
something?
Dobre utka,
Pete Holland Jr.
John Popelish
Guest
Posts: n/a
      04-12-2006, 03:28 AM
Pete Holland Jr. wrote:
> Hey, everybody!
> right track.
> something?
This is certainly a valid way to break this system down into
functional blocks.
Tom Biasi
Guest
Posts: n/a
      04-12-2006, 09:40 AM
"Pete Holland Jr." <(E-Mail Removed)> wrote in message
news:e1hqlu$229$(E-Mail Removed)...
> Hey, everybody!
> the
> right track.
> then
> flowed
> and
> something?
> Dobre utka,
> Pete Holland Jr.
For a simple tuned circuit you can surely look at it that way.
Tom
Walter Harley
Guest
Posts: n/a
      04-12-2006, 04:31 PM
> flowed
> and
You can think of a transistor as a device where a small current flowing
through one part of it (specifically, the base-emitter junction) controls a
larger current through a different part of it (the collector-emitter
junction). So, that does tend to mean that the transistor acts as a bridge
between separate parts of the circuit, although it doesn't have to always be
that way.
In your case, the signal from the antenna is creating a small current that
flows through the BE junction; that controls a larger current (whose power
source is the battery) that flows through the CE junction and also through
the speaker or earphone.
Note that a transistor does not create power (or current or voltage), all it
does is control it. It's like a valve.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
Re: Satellite radio - radio validation Bob Monsen Electronic Basics 0 04-20-2008 04:53 PM
FA: Radio (RF Type) Short Range Controller-Can be used for various radio type projects !!Lou Electronic Equipment 0 12-31-2005 04:32 PM
FA: ICOM RADIO & RADIO SHACK SIMPLEX REPEATER-WORKS GREAT-Gotta look at this ! !!Lou Electronic Equipment 0 12-05-2005 03:50 PM
That legendary Field-Strength Meter: the latest... Paul Burridge Electronic Design 20 01-26-2004 07:09 PM
National Radio Institute Kit Radio dale allen Electronic Repair 2 10-31-2003 10:43 AM
