Electronics Forums
Electronics Forums > Newsgroups > Electronics Newsgroups > Electronic Design > PWM with SG3525
Reply
Thread Tools Display Modes
PWM with SG3525
parkc23
Guest
Posts: n/a
      08-13-2004, 05:57 PM
Hi, could anyone help me with SG3525?
I have a PWM circuit with SG3525 and need to modify the circuit so
that I can get ~0.2 Hz cycle period. This is very slow compared to
all of the circuits that I can get.
Probably, I can change the frequency by changing the capacitor or
resistor at Rt and Ct (pin 5 and 6), but I don't know the equation to
calculate those.
Please help me!!!
legg
Guest
Posts: n/a
      08-13-2004, 08:22 PM
>calculate those.
>Please help me!!!
data at
http://www.microsemi.com/datasheets/SG1525A.pdf
The lowest frequency range specified for this device, using the
internal oscillator is 100Hz. The use of timing C values larger than
100nF isn't documented. I expect larger C values might be acceptible
if an external device was used to discharge it - a small mosfet driven
by an external signal to the sync pin might suit.
Bias current into the C timing pin is between 2 and 20uA, so this
limits the size of the timing resistor to ~150K, if charging time
isn't to be severely affected over temperature. This would require
~16uF timing capacitor to get down to near 0.2Hz.
Have you got frequencies and periods mixed up? For a 50Hz (.02uSec)
operation, with outputs operating out of phase, the oscillator needs
to run at 100Hz. (.1uF/30K or .02uF/150K)
The internal oscillator has a fairly simple internal structure,
allowing external clock drive.
As I recall, the 3525 comparator wass not latched. The 3525A version
latched, allowing only one output pulsewidth per timing period. This
is a usefull feature, so recheck your part number.
At the low frequency stated, you might get better results with
non-integrated components.
RL
parkc23
Guest
Posts: n/a
      08-14-2004, 01:01 PM
legg <(E-Mail Removed)> wrote in message news:<(E-Mail Removed)>. ..
> >calculate those.
> >Please help me!!!
> data at
> RL
Thank you so much!!!
The load is a solenoid (12V, 250mA) and I just don't know if a 16uF
capacitor can discharge it. Do you think it is OK?
As to the latching, does it generate multiple pulse width within a
period if it does not latch regardless of the circuit?
I tried the frequency equation on the data sheet
(f=1/Ct(0.7Rt+3Rd))but got a wrong number. Should I use a different
equation??
Finally, could you let me know the circuit with non-integrated
components? I am only a beginner in the electronics and don't know
much.
Thanks again.
cmp.
legg
Guest
Posts: n/a
      08-14-2004, 04:59 PM
The load in your circuit will not be involved directly with the timing
components.
If the SG3525 is used to drive a solenoid, directly, as a load, the
timing priods required will depend on the magnetic characteristics of
the solenoid itself and the physical characteristics of the
mechanically-coupled armature's load.
Multiple pulse widths are possible if the feedback signal varies
within the timing period, unless the first pwm comparison is latched
and disabled until the next clock timing period.
>equation??
As long as your units are Farads, seconds and ohms, the result in Hz
should be pretty unambiguous. Post your numbers if you want your math
checked.
>much.
You indicated originally that you were modifying an existing piece of
hardware. If you have a schematic of this device, it might be quicker
if you can copy it to ABSE.
RL
parkc23
Guest
Posts: n/a
      08-14-2004, 10:04 PM
Thanks again.
I attach the link for the circuit.
http://home.att.net/~wzmicro/3525.html
If magnetic properties of the solenoid as a direct load affect the
operation of PWM, how can I isolate each? (maybe, some kind of
interface??)
Also, if latching is necessary, can I directly replace SG3525 with
SG3525A?
I am still confused if I can go upto 16uF to get 0.2Hz or higher Rt.
What about the circuit with non-integrated components?
I can choose any circuit since I have not started building any yet.
Thanks.
cmp.
R.Legg
Guest
Posts: n/a
      08-15-2004, 06:33 PM
(E-Mail Removed) (parkc23) wrote in message news:<(E-Mail Removed). com>...
>> with the timing components.
>> a load, the timing periods required will depend on the magnetic
>> characteristics of the solenoid itself and the physical
>> characteristics of the mechanically-coupled armature's load.
>>> within a period if it does not latch regardless of the circuit?
>> varies within the timing period, unless the first pwm comparison
>> is latched and disabled until the next clock timing period.
> interface??)
> SG3525A?
I suggest that you do not have sufficient grasp of the finction of
the 3525 PWM function, yet, to modify the original circuit.
I suggest that if you want to learn about the 3525 and pulse-width
modulation, then you should build the circuit as described, with the
components suggested in the reference and then use it to turn the
solenoid on and off by adjusting the rheostats intended originally to
alter motor speed. You could then figure out how to command the 3525
to turn the solenoid on and off at your intended low frequency rate by
manipulating the appropriate analog or digital control line with a
cmos 555.
The 555 could be used to control a simple bipolar of mosfet switch to
do the same thing, without going through the PWM controller, if
switching the solenoid is your only aim.
http://www-s.ti.com/sc/ds/tlc555.pdf
RL
parkc23
Guest
Posts: n/a
      08-16-2004, 02:42 AM
I guess I need more homework before asking questions. Could you
recommend a good book for the PWM and 555, not too difficult? I am
reading a book by Malvino (Electronic Principles), but this touches
those relatively briefly.
By the way, the reason I need a solenoid control is that I want to
control a 3-way solenoid valve where fluids A and B coming in and a
certain ratio of mixture A and B going out by changing switching
between A and B by simply turning a potentiometer. However, the
solenoid valves are not designed to operate at that high frequency.
That's why I need a very slow PWM.
Would it be possible to do this just by 555 timer without using PWM?
Can I get a circuit?
Thank you.
Ken Smith
Guest
Posts: n/a
      08-16-2004, 03:38 AM
In article <(E-Mail Removed) >,
Ascii art:
1N914
! ! ! CMOS 555 !
\ !--------!thr Q!------- Out
Out -->/ ! ! !
\ !--------!trg !
100K ! !
--- 1U
GND
Is this what you mean. As you turn the pot from end to end the duty cycle
of the Out signal varies from about 0% to about 100%. You just need to
make it so that Out being high turns on A and out being low turns on B.
(E-Mail Removed) forging knowledge
parkc23
Guest
Posts: n/a
      08-16-2004, 12:58 PM
(E-Mail Removed) (Ken Smith) wrote in message news:<cfpa7d$nic$(E-Mail Removed)>...
> Ascii art:
> 1N914
> ! ! ! CMOS 555 !
> Out -->/ ! ! !
> \ !--------!trg !
> 100K ! !
> --- 1U
> GND
Yes, this is exactly what I want!!
Could you get me a more complete circuit? (if it's better for you to
attach file, you could email me as an attachment.)
What's coming in and what's going out? I guess I hook up the
solenoid(12V, 250mA) directly to the pin out, but not sure how I
configure the pot in the input side.
In my humble electronics book, there is an example of astable
operation, but it only operates the duty cycle of 50~100%. Here is
the equation for the duty cycle.
D=(R1+R2)/(R1+2R2)
So, theoretically, the shortest duty cycle only goes down to 50%.
Is it possible to get a range of 0~100% duty cycle in your circuit?
Thanks.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
PWM Control IC Problem (SG3525) alphamnemonic Electronic Repair 8 07-17-2008 06:49 PM
Sg3525 pwm motor control ir comp jeffrun General Electronics Chat 0 10-08-2007 07:35 PM
isolated feedback for SG3525 Anthony C Smith Electronic Design 2 06-12-2006 01:26 PM
Should I use a SG3525 ? Pooh Bear Electronic Design 16 12-01-2004 06:26 AM
PWM with SG3525 parkc23 Electronic Basics 1 08-14-2004 04:05 AM
