Morris Dovey wrote:
> If you're willing to widen your search to include other external
> combustion engine flavors, you might consider Stirling engines - and, in
> particular, the fluid piston fluidynes.
Thanks for the tip, Morris. I had initially discarded this type of engine because after looking
into it I was left with the idea that their use was basically limited to gimmicky, non-power
generation applications such as small table-top toys. After a bit more reading I've noticed that
although their efficiency is rather low, there are quite a lot of qualities that make these sort
of engines an interesting option to consider.
> Do civil engineering students study thermodynamics? [Be careful how you
> answer.
I don't see why any civil engineering student wouldn't be able to study thermodynamics, although
it would be something that they would have to do in their spare time. According to the courses
I'm familiar with, the typical civil engineering course includes an introductory course on
thermodynamics and then puts a bit of emphasis on fluid mechanics. That is, obviously, not
comparable with the emphasis that mechanical engineering courses place on thermodynamics, even
when ignoring specific courses covering turbo-machinery.
Nonetheless, this is a bit of a non-issue in this particular discussion. I don't plan to build a
power plant from scratch, which would be quite a hefty task to pull off. All I want is to get
information about the available options to generate power in an off-the-grid scenario. Solar power
is a nice option, provided that we focus on solar-thermal. That option becomes even more
interesting if it's possible to complement it with biomass. Yet, it all boils down to (pun
unintended) how we convert heat to mechanical energy, and there is virtually no relevant info on
this subject.
Rui Maciel
