On 9 Jul 2006 17:11:35 -0700, "DJ" <(E-Mail Removed)> wrote:
>http://www.danby.com/manuals/DPR2262.pdf
Thanks for the link. I looked all over the web for any info about
Consul fridges with little luck. I never thought of Danby.
>> difficult and a service call out of the question.
>Out of idle curiosity, where?
The cabin is located on a remote lake in Central Nova Scotia.
>I'd bet dollars to donuts your exhaust is plugged.
I'd love to think that it's just the exhaust. In fact, I've had
trouble with the exhaust before. The fridge worked good when I first
bought the cabin but after a few months it became difficult to get it
to stay lit. It would work fine for a few hours and then just go out.
After a bit of calling around someone told me about the brush hanging
from the back of the fridge and how to clean the exhaust with it. When
I first cleaned it with the brush large chunks of hardened soot fell
from the chimney down into the firebox. I cleaned the soot and other
debris out of the firebox and even re-ran new exhaust and air intake
lines. The fridge worked a bit better for a while, but now I have the
current problem of lack of cold. The fridge still doesn't seem to run
all that great. Like I said, the indicator shows it's barely running
at all, although there's a good flame present in back.
During this past weekend I even took the exhaust line off the fridge
all together and let it run like that for a few hours. The fridge is
installed between two rooms, with the back of the fridge extending
into a storage area. All the exhaust gas went out there - not into the
living quarters. This is one of the reasons why I don't want to move
the fridge -- it's actually installed in a wall and siliconed all the
way around. It would sure be a headache to move. Anyway, running the
fridge with no exhaust line attached made absolutely no difference, so
it's definitely not the line itself.
So aside from using that brush some more (which I just tried two days
ago with no effect), how do I clean out the exhaust any better? I took
the exhaust apart before and there's no way to get at anything in
there. It doesn't look like there's much a person can do in there
other than brush his brains out from the top of the chimney.
I've never heard of this "screw vortex plug". What is that?
I can't see the propane pressure having changed. I use 100lb tanks and
the one hooked to the fridge is almost full. The same regulator and
lines have been used from the beginning and they all look fine.
Thanks for all the input into this matter. I sure hope to be able to
repair this problem myself. I thought these fridges were supposed to
last for years. Mine's still basically brand new and I have nothing
but trouble with it. Maybe the fact that it is turned off about 98% of
the time makes a difference.
