"David L. Jones" <(E-Mail Removed)> wrote in message
news:(E-Mail Removed) oups.com...
> Abstract Dissonance wrote:
>> I'm going to try to program a simple keyboard translator using the
>> PIC2455
>> which has a built in EUSART. At this point I just want to get the
>> keyboard
>> codes into the pic and I just want to run this by you guys to make sure
>> I'm
>> on the right track.
>> 1. Setup hardware. Basicaly just have to connect the Data and Clock lines
>> to
>> the EUSART pins on the pic
>> 2. Enable the USART on the pic for Asynchronous mode and enable auto baud
>> rate dection(to make it easy).
> No. You will need *synchronous* slave mode which uses the external
> clock from the keyboard.
Why is this? Wouldn't the auto baud rate detect and interrupts work? I will
look at it though and see... I'm not to familiar with the different methods.
I was thinking that each time the clock pulsed it would trigger an interrupt
and you could read the data off the data line and store it... or something
like that.
>> 3. Read the RCREG in the interrupt and do whatever with it(like make an
>> LED
>> blink on certain codes).
>> Is that basicaly all I have to do? Do I need to use pullups or anything
>> when connecting the lines or even use transistors to source/sink more
>> current?
> Yes, use pullup resistors.
>> (I'm running the keyboard off a 5V supply that can source up to .5mA or
>> so)
> The keyboard takes a lot more than 0.5mA!
Sure
> Dave
Jon
