Electronics Forums
Electronics Forums > Newsgroups > Electronics Newsgroups > Electronic Basics > PCB Making with inkjet printer
Reply
Thread Tools Display Modes
Peter
Guest
Posts: n/a
      08-08-2003, 03:01 AM
It occurs to me that if you were to fill an inkjet printer cartridge
with a non-water based ink, you could just modify a cheap printer or
plotter and print directly onto the copper and then etch in normal
etchant. Forget about iron-ons and all the other one-off methods. I
can't find any reference to it anywhere. Any reason why it wouldn't
work.
Joe McElvenney
Guest
Posts: n/a
      08-08-2003, 10:25 AM
> work.
I should think that the rather viscous ink that you would need
might block the cartridge holes. However, this method has been tried
with pen plotters using refillable pens. What the ink was I do not
know but would like to as I have a Roland plotter that I might try out
one day.
Cheers - Joe
Brett
Guest
Posts: n/a
      08-08-2003, 02:28 PM
"Joe McElvenney" <(E-Mail Removed)> wrote in message
news:(E-Mail Removed)...
> Hi,
> > work.
> one day.
The other problem is the bending of the pcb that would be required or major
printer moddifications. Though you can get pcb that is flexible enough for
the job.
I have tried all the home brew methods people have thought up, and the only
one that worked well was the photographic method. While more expensive, the
results are spectacular and sooooo hands off compared to other methods. (And
they look neat if you use MG Chemical's photosensitive boards which are dark
green.)
For the pen plotter method, I had ok results, however ground planes were
impossible and the track width is limited to 24mils and greater in my case.
It also took long periods of time to plot. The other major problem with this
method is that the etchant tends to eat away at the tracks slightly.
Brett
> Cheers - Joe
Joshua K Drumeller
Guest
Posts: n/a
      08-09-2003, 04:17 AM
I remember a few years back seeing an advertisement for a product just like
this in one of the electronic magazines. It was either Popular Electronics,
Electronics Now, or Poptronics. I too, have also inquired about this in the
newsgroup with no success but I know I saw it. It must not be very good or
else it would be more popular.
Josh
"Peter" <(E-Mail Removed)> wrote in message
news:(E-Mail Removed) m...
> work.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
Making an ink-level sensor for an inkjet printer Al Deveron Misc Electronics 17 08-31-2006 06:12 PM
Making an ink-level sensor for an inkjet printer Al Deveron Electronic Basics 25 08-31-2006 06:12 PM
Hacking an Inkjet Printer MMS Electronic Design 4 08-26-2005 06:07 PM
Hacking An Inkjet Printer MMS Misc Electronics 1 08-26-2005 05:42 PM
Canon inkjet printer Michele Smith Electronic Repair 2 08-26-2004 01:00 AM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93
