Electronics Forums
Electronics Forums > Electronics Forums > Circuit Help > PCB Layout
Reply
Junior Member
      02-10-2010, 07:40 PM
need a pcb layout for a project i have but i am not soo good in pcb design, would be very thankful if someone can do both sides, component placing and copper bottom
Super Moderator
(*steve*)'s Avatar
Location: Mid way between Beijing and the the Ronne Ice Shelf (mind your projection)
      02-11-2010, 12:27 AM
Now is a good time to learn!
What tools have you tried?
Here are some links that might help:
http://www.pcbdesign.org/
http://www.expresspcb.com/
http://www.alternatezone.com/electronics/pcbdesign.htm
http://www.freepcb.com/
Junior Member
      02-12-2010, 01:04 PM
made in express PCB, please help , right ? wrong? what? You need to remove the .txt for it to open in expresspcb
Junior Member
      02-16-2010, 08:11 PM
Someone? right ? wrong?
Super Moderator
(*steve*)'s Avatar
      02-17-2010, 08:07 AM
I looked at that this morning and then got distracted with work(!)
When the file is opened it complains that the schematic is missing (C:\Users\MrGree\Documents\4.sch)
If you can post that it would be useful. -- OK, the schematic is shown above.
It looks OK, however I would change the following:
1) Use wider tracks. There is no reason to use such narrow tracks
2) Use larger pads if possible. The ones you have are the minimum size.
3) For your +5V input, use larger pads and place them further apart
4) Be very careful placing text on the board. The "D" in TXD is very close to shorting out two tracks.
5) If the yellow box defines the extent of your board, then you have tracks outside of it.
6) Check that you're not supposed to do something with the unused pins of this IC
7) You have placed all the tracks on the top of the board instead of the bottom. This will cause you no end of headaches because you'll have to put the IC and the socket on the underside of the board (which may make them difficult to solder).
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
Export layout netilst by Mentor Calibre PEX boki Electronic Basics 0 09-18-2003 03:31 AM
Export layout netilst by Mentor Calibre PEX boki Electronic Design 0 09-18-2003 03:30 AM
RG ground plane, layout JB General Electronics 0 07-30-2003 09:49 PM
Please help with PCB layout Owen Lawrence Electronic Basics 3 07-25-2003 01:11 AM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93
