Electronics Forums
Electronics Forums > Newsgroups > Electronics Newsgroups > Hobby Electronics > PC oscilloscopes and real oscilloscopes
Reply
Thread Tools Display Modes
Mike
Guest
Posts: n/a
      08-28-2004, 04:17 PM
My 40 year old valve oscilloscope blew the mains fuse. I replaced the fuse but
now it just makes suspicious something-is-getting-hot-and-might-explode sort of
crackling noise (as if one of the electrolytic capacitors is getting ready to
make a quick exit). Given its age it's probably not worth spending the time
trying to figure out what's wrong.
I'm looking for a replacement with 2 channels and a 10MHz bandwidth. Looking at
Dick Smith and Jaycar it looks like $500 for a real scope or $300 for a single
channel (low resolution) LCD screen scope.
Does anyone have experience or recommendations for a PC scope, either a plugin
card or an external box that plugs into the parallel or USB port ?
Using the sound card isn't an option because of the low sample rate.
Mike
John Smyth
Guest
Posts: n/a
      08-28-2004, 07:27 PM
"Mike" <(E-Mail Removed)> wrote in message
news:(E-Mail Removed)...
but
sort of
to
time
Looking at
single
plugin
> Mike
Did you have a look at what scopes you can get secondhand on ebay?
www.ebay.com.au
John Smyth
David L. Jones
Guest
Posts: n/a
      08-29-2004, 12:26 AM
Mike <(E-Mail Removed)> wrote in message news:<(E-Mail Removed)>. ..
> Mike
Hi Mike,
Unless you need the digital storage or spectrum analysis capabilities
of a PC scope, stick with a proper analog scope. You will find analog
scopes still have the lead in ease of use, responsiveness, bandwidth
and dynamic range. You need a fairly expensive high end digital scope
to even start to come close.
Also avoid the cheap handheld LCD scopes unless you obsolutely need
the portability, they are just toys.
Don't buy a new scope from the like of DSE or Jaycar, they are very
poor value for money. Instead get yourself a second hand or
reconditioned scope. These can be had on eBay, Oatley or Macservice
(http://www.tmgestore.com.au/). For the same price as a new 20MHz
Jaycar/DSE no-name unit you can get yourself a nice 100MHz+ brand name
scope.
Trevor Wilson
Guest
Posts: n/a
      08-29-2004, 11:16 PM
> but
> sort of
> to
> time
> Looking at
> single
> plugin
**Find a nice used Tektronix. They go forever and perform beautifully. My
favourite is the 465B.
Trevor Wilson
www.rageaudio.com.au
John Crighton
Guest
Posts: n/a
      08-30-2004, 01:57 AM
On Sun, 29 Aug 2004 00:17:57 +0800, Mike
<snipped>
>Mike
What is the make and model is your faulty scope? Just interested to
know. Maybe it is not as bad as you think. Have you had a look inside?
Regards,
John Crighton
Hornsby
John Crighton
Guest
Posts: n/a
      08-30-2004, 02:38 AM
On Sun, 29 Aug 2004 23:16:22 GMT, "Trevor Wilson"
>news:(E-Mail Removed).. .
>> but
>> sort of
>> to
>> time
>> Looking at
>> single
>> plugin
>Trevor Wilson
Hi Trevor,
I have been hankering after one of those 465Bs for a a couple of
decades but I haven't been lucky enough to come across a good
cheap one for less than $400.
Just lately I must admit that my opinion of old BWDs has risen and
that of old Tektronix scopes has dropped slighty. Special Tek ICs
makes fixing old Tek stuff a lot harder. I have been told that there
are only a couple of hard to get special bits in the 465B so I am
still interested in finding one.
More of a want rather than a need. :-)
Regards,
John Crighton
Hornsby
Trevor Wilson
Guest
Posts: n/a
      08-30-2004, 09:54 AM
"John Crighton" <(E-Mail Removed)> wrote in message
fuse
> >> but
> >> sort of
ready
> >> to
> >> time
> >> Looking at
> >> single
> >> plugin
> >Trevor Wilson
> Hi Trevor,
**$400.00 is still pretty decent value. After you've used one for awhile,
you begin to appreciate what quality is all about.
**I know the feeling. I have three Tek 'scopes (454, 465b and 2430A
digital), one Philips PM3256 and a BWD 521. The BWD and the Philips require
regular cleaning of switches and pots. The Teks do not (the 454 and 465 get
used every day). The BWD has required some power supply rebuilding too.
Having said all that, the BWD is easy to work on, the Philips is a PITA. The
Teks don't ever need servicing, apart from calibration (and the odd Nuvistor
replacement in the 454). Well, except for the 2430A. It requires some work
and I don't have the balls to attempt it (yet).
BTW: If you do buy a Tek 'scope, get a Tek probe with it, if you can.
They're bloody excellent.
Trevor Wilson
John Crighton
Guest
Posts: n/a
      08-30-2004, 01:02 PM
On Mon, 30 Aug 2004 09:54:03 GMT, "Trevor Wilson"
>Trevor Wilson
I just bought an old 454 recently. It is working but has a few little
problems that I can live with for the moment.
When changing the input attenuator switch, the trace shifts up or
down. The shift control has to be readjusted to bring the trace back
to the same reference position. A slight pain. :-)
This 454 uses nuvistors also. Where did you find your spare
nuvistor Trevor, locally or overseas?
I like the transistor sockets on this 454. Not all the boards have
transistor sockets, just some, but it is a nice thought for the
maintenance techs.
The BWD 820 model is nice to work on. Easy to get at everything.
I was removing a fan and some associated bits from a junked carcass
453 for another enthusiast and I was disappointed by the way the
wiring prevented assemblies from being moved more than slightly.
I was expecting assemblies to neatly flip out the way on their wiring.
Nope! They didn't.
The Rolls Royce quality that I was expecting from that famous
Tek myth wasn't here, accessibility wise, on this unit.
The other problem with my 454 is all time base ranges are slightly
out by the same amount. I can get over this by just moving the
red knob in the centre of the timebase switch slightly away from
the "cal" position. There is a pot inside that is supposed to adjust
the overall time base accuracy but it is not adjusting as expected.
The displayed waveform lengthens then shrinks as the pot is
turned in the same direction. The pot doesn't check open circuit
but I will look into that later. I have a habit of trying to make
things just a little bit better and then stuffing something. :-)
$100 for a 150MHz CRO, I am happy with it.
If you are into Tekscopes Trevor or if anyone else is interested,
I have a couple of boat anchor size valve types that I would like
to give away to a good home for free. Model 533A and model 549.
Both not working but there was signs of a trace on both scopes.
Here is a picture of similar scopes.
http://www.cse.uta.edu/TheMuseum@CSE...pe%20frmed.jpg
http://www.google.com.au/search?q=ca...cope+549&hl=en
The ones I have are a bit shabby not nice like the pictures.
You mentioned Philips scopes Trevor. Maybe you know this
model from my description. I just can't remember the model
number. Twenty years ago at one place I was working there
was a little two tone grey Philips cro with a grey hard plastic
pouch like container at the back of the CRO for storage
of the operators manual and probes. Pouch suggests something
soft , this thin container was hard plastic but I don't know
what else to call it. The CRO was 15 Mhz bandwidth.
I have been looking for this model PM??? for use as a battery
operated CRO. Back then, I modified one of these CROs to
run off 24 Volts DC.
The power supply was just transformer, bridge and cap to one
main regulator, approximately 24V DC input. So it was easy
to use a couple of small batteries for a few hours running
where 240V was not available on outside jobs or for using
it for testing circuits where the CRO could float. Not earthed.
It was very handy for that.
I just missed out on buying one years ago for $30 and haven't
seen another since. I can't recall the model number. Maybe
you know of it Trevor.
Regards,
John Crighton
Hornsby
Mike
Guest
Posts: n/a
      08-30-2004, 04:20 PM
It's a Telequipment D43.
There's no obvious burn marks or bulging caps.
I'm concerned that something may go bang if I try to find the source of the
sound while it's switched on. Bits of capacitor flying around the room is
something I'd rather avoid.
Mike
John Crighton
Guest
Posts: n/a
      08-30-2004, 11:11 PM
On Tue, 31 Aug 2004 00:20:06 +0800, Mike
>Mike
Hello Mike,
here at the aus.electronics factory the boys are not going
to let you off with that weak excuse for not fixing your CRO :-)
Cripes! you are more likely to get hurt slipping on a floor at the
supermarket, getting run off the road by a driver who is drunk,
dopey on medication, high on drugs or just plain stupid/senile
or hasn't been to sleep for 24 hours or more. You go out on
the road and and mingle with dangerous bastards like that and
now you are backing off from helping a nice little CRO that is
crying out for your help. Aw c'mon Mike :-(
Here is a place to down load the circuit diagrams.
http://www.thevalvepage.com/servdata...q/telequip.htm
The fourth item down the page is your D43.
We are all here to help you.
Regards,
John Crighton
Hornsby
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
OT: Real Men drink Real Milk Rich Grise Electronic Design 4 01-05-2008 03:37 PM
Mixed Signal Oscilloscopes vs Digital Signal Oscilloscopes (MSO vs DSO) benn686@hotmail.com Electronic Basics 3 12-13-2005 11:27 PM
Vendee Globe virtual following in real time and real winds Hervé Le Cornec Boat Electronics 0 10-27-2004 11:10 AM
Real Hardware Digital Real-time Synth Radium General Electronics 0 12-22-2003 05:12 AM
Are there any real techs on here that work for a real shop? Jack Electronic Repair 24 11-23-2003 05:54 AM
