"Charles" <(E-Mail Removed)> wrote in message
news
(E-Mail Removed). ..
> "David" <(E-Mail Removed)> wrote in message
> news:T-(E-Mail Removed)...
>> I'm a bit confused about the ground clip on oscilloscope probes. I have
>> read that it can cause a ground loop when the measurement circuit is
>> grounded to the same ground as the oscilloscope itself. Is the ground
>> clip only to be used when there is an isolated ground then?
>> I have been taking measurements from 12V car batteries and DC power
>> supplies. Should the ground clip always be used in these cases?
>> If I am correct the ground clip should not be used to measure between two
>> voltages as one would do with a multimeter (referencing a different
>> voltage in the circuit instead of its ground). It confuses me why I
>> would not be able to use the ground clip to do that. An explanation/link
>> would be appreciated.
> Line operated equipment and bench oscilloscopes often lead to ground
> loops. A big spark erupts when the ground clip touches the chassis! Has
> probably happened to most workers at least once. Often, the circuit
> breaker trips and that is the end of the matter (other than a burnt clip
> end and soiled underwear). The reason is that the clip is grounded
> through the 3-wire power cord on the scope. If the equipment is not line
> isolated, it is possible for the chassis to be hot with respect to ground.
> The short circuit that results is called a ground loop.
> Solutions:
> 1/ Isolation transformer for the equipment (best) or the scope (shaky).
> 2/ Use the differential mode on a dual channel scope (be careful about
> common mode voltage ratings).
> 3/ Use a separate differential amplifier before the scope.
> 4/ Use a battery-operated scope (again, one must observe the scope's
> voltage ratings).
> 5/ Make a floating measurement (use an adaptor to defeat the scope ground
> ... this is dangerous but is often done ... please AVOID this method).
> Hope that helps.
Thanks Charles.
I'm guessing DC power supplies are usually isolated or is it typical for the
negative to be connected to the line ground? I will check this with a
meter.
If the DC supply IS isolated (or if I am using a 12V battery):
Can I connect the ground clip to any point of the circuit and measure the
voltage of another point with respect to the one the ground clip is
connected to (as I would with a multimeter) or is there some reason that the
ground clip should be connected only to a terminal?
I think I'll avoid the ground-defeating adaptors in hopes of having a better
understanding of ground loops some day (I have read about these in the past,
I'm not sure why I'm having such a difficult time getting the concept down).
I will investigate differential mode on a dual-channel scope. I thought
this would involve using two ground clips and two probes and show the
difference between the two probes but I may be way off on this.
Thanks again,
David
