Electronics Forums
Electronics Forums > Newsgroups > Electronics Newsgroups > Electronic Repair > Open IOmega external USB2 hard drive case?
Reply
Thread Tools Display Modes
larry moe 'n curly
Guest
Posts: n/a
      03-11-2005, 07:46 AM
I have an IOmega external USB 2.0 hard drive, model DHD080-U (USB 2.0
only, no FireWire). Does anybody know how to open its case so I can
install a bigger hard drive?
There are three screws on bottom, near the front, but they release only
the front of the case. I didn't find any other screws under the
sticker or rubber feet.
Also does anybody know how large a hard drive the IOmega USB enclosure
will handle?
Jerry G.
Guest
Posts: n/a
      03-11-2005, 08:02 AM
Some of there cases have surface rubber feet, or inserted rubber feet.
Remove the rubber feet to gain access to the screws under them. This is the
case for most of these types of utility boxes.
Jerry G.
"larry moe 'n curly" <(E-Mail Removed)> wrote in message
news:(E-Mail Removed) ups.com...
will handle?
larry moe 'n curly
Guest
Posts: n/a
      03-11-2005, 12:25 PM
> rubber feet. Remove the rubber feet to gain access to the
> screws under them. This is the case for most of these types
> of utility boxes.
Thanks, Jerry. I found two hidden screws under them and opened it up.
The ventilation of this drive doesn't seem to be very good because the
case has almost no openings, and the IDE drive inside has a metal cover
over its PC board that blocks all air flow. I'm thinking of
drilling holes in the cover.
dg
Guest
Posts: n/a
      03-13-2005, 07:58 AM
If you drill holes, just be careful of staples and other office crap that
might get onto the PCB and cause problems.
--Dan (who once dropped a full box of paperclips onto his running
motherboard without problem)
news:(E-Mail Removed) oups.com...
larry moe 'n curly
Guest
Posts: n/a
      03-13-2005, 12:16 PM
> crap that might get onto the PCB and cause problems.
Good idea. Fortunately the adults here are very careful, and the
electric shock dog training collar we put around our kid's neck has
been very effective in preventing mischief, especially ever since it
was rigged to be triggered automatically by any of the numerous motion
sensors around the house.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
Iomega Zip Z100P2 drive ian field Electronic Repair 9 09-18-2006 03:39 PM
Stream Data Directly to External Hard Drive jjlindula@hotmail.com Electronic Design 5 03-09-2006 07:07 PM
old iomega scsi zip drive died Mark Modrall Electronic Repair 6 11-27-2004 09:37 AM
Power supply for Iomega External 4 x 4 x 6 Burner Dingo Dan Hobby Electronics 1 10-15-2003 11:55 AM
replacement part for iomega 100 usb zip drive Ting F. Chui Electronic Repair 2 10-09-2003 07:55 PM
