On 8 Apr 2006 08:32:18 -0700,
(E-Mail Removed) wrote:
>Sorry for the double reply, but Google Groups isn't displaying this on
>their site because it associated the title with another post. Hopefully
>it will appear on deja.com by changing the title.
>Kevin Aylward wrote:
>> pmlonl...@gmail.com wrote:
>> > Hi,
>> > I'm looking at an op-amp graph of total noise vs source resistance. The
>> > noise increases with an increase of source resistance. Does this also
>> > apply to reactance?
>> > The way I understand it is resistance is thermal noise, but reactance
>> > from inductors and caps don't caused any noise. Real L's and C's have
>> > some R, but in that sense they have noise.
>> > Some details:
>> > I have an input coil antenna that's 22 ohms R and about 10 mH. Nothing
>> > fancy, just a round loop coil with a lot of turns. Typical frequencies:
>> > from 1KHz to 1MHz. At say 1MHz the reactance would be just over 6 M
>> > ohms. The chart, "Total Noise vs Matched Source Resistance" at
>> > http://www.linear.com/pc/downloadDoc...C1,C1154,C1009,...
>> > According to the chart a 6 M ohm source resistance would have
>> > outrageous noise. Is it safe to say the 6 M ohm reactance (for 1MHz
>> > signals) will cause no noise? Rather the noise will come from the 22
>> > ohms R? According to the chart, 22 R at 1KHz is ~ 1 nV/SqrtHz. Not sure
>> > what it would be at 1 MHz, but it seems lower than 1KHz.
>> > The charts is for "Matched Source Resistance." The coil is one
>> > continuous resister, so if I place the 2 coil leads directly to the
>> > op-amp then is that considered matched? I'm using a typical
>> > differential op-amp has two input R's. So if the coil's total R is 22
>> > ohms then would that equate to two 11 ohm input R's? Very confusing,
>> > lol.
>> Noise is due to thermal noise *and* shot curent noise. The shot noise
>> current of an amplifier is droped accross the source impedance (and
>> Rin). If the source is an inducter, the voltage noise caused by the amp
>> input current shot noise will increase with frequency despite the fact
>> that the inductor itself does not generate any noise.
>> Kevin Aylward B.Sc.
>> 431infoEXTR...@anasoft.co.uk
>> http://www.anasoft.co.uk
>> SuperSpice, a very affordable Mixed-Mode
>> Windows Simulator with Schematic Capture,
>> Waveform Display, FFT's and Filter Design.
>> "There are none more ignorant and useless,than they that seek answers
>> on their knees, with their eyes closed"
>Let me see if I understand this. A pure inductor cause shot noise, but
>no thermal noise?
A pure inductance *generates* no noise. That would violate
conservation of energy.
> How can I calculate a differential op-amp's output
>noise if the source is mostly inductive? ->
>http://hyperphysics.phy-astr.gsu.edu...opampvar7.html
At any given frequency, multiply the opamp's input current noise
density (in amps per root Hz) by the inductor's impedance; that's the
input noise voltage density, units of volts per root Hz. Multiply that
by amp gain at that frequency to get output noise density. Looks like
you'll need a fet amp here.
To get net noise voltage, you have to integrate the noise density
curve over frequency. Note that, unless the opamp gain rolls off, or
the coil has shunt capacitance, the output noise density (at least
this In*Zin*gain thing) here will increase linearly with frequency,
pretty much forever.
>Note that in my case R1 & R2 are also reactive-- 22 ohm resistance and
>6 M ohm inductance.
>The capacitance is extremely small. So there's no resonance.
>I presume that the noise would be a lot greater if it was 6 M ohm
>resisters rather than inductors.
The resistor would add its own noise, too. At some point, in real
life, pickup from ambient magnetic fields will actually dominate.
That's why HF receivers don't need good noise figures: atmospheric
noise is huge below about 30 MHz. A little 60 Hz hum, or one good AM
station, will entirely blow away any considerations of thermal noise.
John
