Electronics Forums
Electronics Forums > Electronics Forums > Electronic Projects > One switch two light bulbs.
Reply
Thread Tools Display Modes
Junior Member
      11-06-2011, 02:57 PM
For my project Im trying to work out how to make one switch operate two different light bulbs. It's killing me and I'm nearly at the point of giving up. I can see it in my mind how to do it but I can put it into practice. Please can someone help?
I want to use a switch to turn a lamp on like normal, but when I flick the switch, repeatedly (x2) and quickly, the circuit changes to another lamp.
One lamp would be green and the other red (not that its relevant).
I was thinking about a 555 but it's been so long since i played with one I don't think I can achieve it.
Is their an easy way to do this job or is it as difficult as I'm making it!
I hope you can help.
Davy
Junior Member
      11-06-2011, 02:58 PM
I came up with the switch though after using a security alarm that changes to permanently on when you double-switch.
For my project it has to be a single switch.
thanks
Senior Member
OLIVE2222's Avatar
      11-06-2011, 04:08 PM
Hi davy,
If you talk about main powered light bulbs this is the trick:
http://www.dos4ever.com/keukenlamp/keukenlamp.html
Olivier
Junior Member
      11-06-2011, 04:51 PM
Quote:
Originally Posted by OLIVE2222 View Post
Hi davy,
Olivier
Olive,
Your circuit diagram is absolutely unequivocally exactly what I need, thank you so much, I think it's an amazing circuit and I'm glad it served you so well, and for so long. An absolutely amazing, but emotional story, you sound like a great guy.
Thanks again! I will let you know how my project turns out.
Senior Member
OLIVE2222's Avatar
      11-06-2011, 05:03 PM
Davy,
Happy that it's what you are looking for but the design is absolutely not mine.
I just point you to the right direction!
Doesn't mean that I am not a great guy too
Olivier
Junior Member
sheldonstv's Avatar
      11-06-2011, 05:49 PM
Super Moderator
davenn's Avatar
Send a message via Yahoo to davenn
      11-06-2011, 08:00 PM
Hi Sheldonstv
welcome to the forums
not quite what the OP wanted, If you read back through you will see he wanted 2 different lamps on the same circuit to be individually switched
Olivier
that was a great link I hope you and Davy both read the page right to the bottom. a bit of a sad story in may ways. But a nice tribute to Ronald's mom
cheers
Time is an illusion -- Lunchtime doubly so - Douglas Adams
When all else fails.... Read the instructions!
Senior Member
OLIVE2222's Avatar
      11-07-2011, 06:03 AM
Hi Dave,
Yes I have read the sad Ronald story to the end, that's why I was a little bit embarrassed with the littledavyboy reply.
Olivier
Junior Member
DrPinky's Avatar
      11-07-2011, 09:52 PM
Hi davy,
Olivier
This is a really awesome circuit. lots of applications. You could hook the super secret device of doom to an ordinary light switch. MUHAHAHAHA just kidding
Junior Member
sheldonstv's Avatar
      11-08-2011, 08:58 AM
ok heres the revised schematic-2 lights(leds) 1 switch(single pole double throw) and 2 resistors........cant be any more simple than that
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
Re: Compact Fluorescent Light Bulbs on a 3-way switch? Palindrome Electrical Engineering 0 09-18-2007 08:23 AM
Re: Study light / light bulbs Jim Worthey Lighting 5 10-22-2003 01:58 AM
Re: Study light / light bulbs JM Lighting 0 10-21-2003 06:40 AM
Re: Study light / light bulbs Victor Roberts Lighting 0 10-19-2003 11:42 PM
Re: Study light / light bulbs Brandon Anderson Lighting 0 10-19-2003 10:56 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98
