Quote:
Originally Posted by jackorocko
what is this some kind of homework? Who thinks you will build what you want this these parts?
When I first read this I was thinking you'd need a boost converter at the very least. Maybe not depends on what your needs are exactly. You will need to spell out exactly what your load is gonna be if you want more definitive answers.
Yes it's homework. We use Locktronics to build circuits on
The load is a 14V lighting circuit.
I'll write out my brief:
To design and build and test a Normal/Alternate DC uninterruptable power supply with battery back-up to illuminate a 14V lighting circuit.
Objectives
When Both supplies are available, normal supply is to be automatically selected
To automatically switch to secondary in the event of a total mains failure OR an approximate 20% fall in the mains supply
In the event of the secondary also failing or an approx 20% loss in secondary supply, the circuit should automatically switch to battery back-up.
Whilst on battery back-up, with the restoration of normal OR alternate supply, these must automatically select with the priority as above
(then there is some guff about indication LED's)
Equip required
Loctronics components supplied in tool box (I may be able to ask for other basic components)
Dual DC power Supply
Relays
12V battery box
Digital volt meter
My box contains the items listed and unfortunately I don't know what a boost convertor is.
I really feel a little out of my league with this and really don't know where to start.
I was thinking of using transistors as switches or just have the relays switch between the powered paths of the circuit but my electronics knowledge isn't really that good.
