Electronics Forums
Electronics Forums > Newsgroups > Electronics Newsgroups > Electronic Design > NIMH Memory effect
Reply
Thread Tools Display Modes
NIMH Memory effect
Dave VanHorn
Guest
Posts: n/a
      01-18-2004, 04:50 PM
For years, I've followed the conventional wisdom that memory was a myth.
Having seen it documented in a Sanyo data sheet, along with specifics on how
to reproduce it, I decided to try it myself. I had previously built a rig
to test battery charge systems under development, so this just took a few
minutes to alter the code to terminate discharge early, at a specific
voltage point, which simulates a device like a digital camera designed for
4x1.5V running on 4x1.25V.
Well gentlefolk, I have seen it, and it is real.
http://www.dvanhorn.org/NIMH/Index.php
About midway down the page, you'll find the text, how the experiment was
conducted, and the discharge plots showing memory effect after only 10
cycles, and that it's gone, after a single normal discharge cycle.
I'll grant that it's not all that significant after 10 cycles, but it's
definitely there.
I have a 30 cycle test in progress.
A: Because it messes up the order in which people normally read text.
Q: Why is top-posting such a bad thing?
A: Top-posting.
Q: What is the most annoying thing on usenet?
Don Pearce
Guest
Posts: n/a
      01-18-2004, 06:22 PM
On Sun, 18 Jan 2004 11:50:43 -0500, "Dave VanHorn"
>definitely there.
Welcome to the world the rest of us have known for years and years and
years...
d
_____________________________
http://www.pearce.uk.com
Dave VanHorn
Guest
Posts: n/a
      01-18-2004, 10:50 PM
years...
Yeah well..
There's a whole bunch of sources out there, that say it's a myth, and
unfortunately, I believed them.
http://vancouver-webpages.com/peter/nicad.faq
http://www.jlcnet.com/banner/nbp3.html
http://www.antonbauer.com/46-a-Terminology.htm
http://www.straightdope.com/classics/a990312b.html
http://www.k3emd.com/Technical%20References.htm
And so on..
Keith R. Williams
Guest
Posts: n/a
      01-19-2004, 02:34 AM
In article <(E-Mail Removed)>,
(E-Mail Removed) says...
> years...
> Yeah well..
IN the real world, it is a myth. That is, no one is ever likely
to see any such problem, and if they do it's easily correctable,
as you've stated. You've performed a very accuratee test
demonstrating the effect on *one* cell type. Yawn!
What most refer to as "memory" is the destruction of cell(s) by
reverse charging a multi-cell pack or by cooking the poor
bastards in a crappy charger. One is *highly* unlikely to ever
see the dreaded "memory" effect. And not every cell shows even
this.
Keith
Dave VanHorn
Guest
Posts: n/a
      01-19-2004, 03:30 AM
I don't see it as a "yawn", it was not something I'd expected.
I intend to cycle through some more cell types and manufacturers, as soon as
possible.
That certainly wasn't my understanding. The first is reversal damage, and
the second is charge depression, both very different from memory.
> One is *highly* unlikely to ever see the dreaded "memory" effect. And
not every cell
> shows even this.
Hmm. I got lucky then? 1 for 1.
Admittedly a small sample.
I have a large number of the HR-AUC packs available for testing.
I'm running a 30 cycle test now, which should be interesting, relative to
the 10 cycle test earlier.
In the future, I plan to run cycles to a specific discharged energy (kJ)
rather than voltage, and to dithered points, to determine the effect of the
variation of the discharge point on the total effect.
The nice part is that it's pretty much automated, I just have to set it up,
and let it run, and save the data at the end.
Ben Bradley
Guest
Posts: n/a
      01-19-2004, 04:08 AM
Your subject says NIMH. For decades I thought it was NiCad cells
that allegedly had this alleged mythcal memory effect.
Are you claiming these are the same, or is there a separate alleged
memory effect myth for NIMH cells?
http://mindspring.com/~benbradley
Dave VanHorn
Guest
Posts: n/a
      01-19-2004, 04:35 AM
"Ben Bradley" <(E-Mail Removed)> wrote in message
news:(E-Mail Removed)...
I haven't personally tested NICAD yet, but I suspect it will be same, or
worse.
NIMH manufacturers disagree on wether there is, or is not memory in NIMH
cells, Sanyo, who makes the particular cells I tested, says there is. I
intend to test some Panasonic cells soon, which come from the "no memory"
camp, under identical conditions.
Wether the electrochemistry is the same or not, I can't say for sure, but
since they are both nickle based chemistries, I suspect it's the same, or
very similar.
The 30 cycle test on the Sanyo HR-AUC cells is nearly done, I should have
the data online in a couple hours.
I might start the Panasonics off next, as I have a pack made up already.
Mac
Guest
Posts: n/a
      01-19-2004, 07:45 AM
> possible.
> not every cell
>> shows even this.
I for one always appreciate knowing the complicated truth rather than a
simplified version of it. That is, if there is a mild and easily overcome
memory effect associated with a particular cell, I would rather know the
details than just have someone tell me "memory effect is a myth."
What I have always read and believed was that NiCad cells really do have
a memory effect, but that it is only detectable when a battery is
discharged very regularly to a specific level over and over again. In
practice, this is not what most people do. This is why knowledgeable
people often say that memory effect is a myth, I guess.
Also, there are lots of people out there who ruin their batteries by
overcharging or discharging too far (so that the weakest cell is
reversed), and they mistakenly call it "memory effect." This is another
reason why people like Keith go around saying memory effect is a myth.
Mac
Keith R. Williams
Guest
Posts: n/a
      01-19-2004, 03:25 PM
In article <zPKdnRxhqYqz0pbdRVn-(E-Mail Removed)>, (E-Mail Removed)
says...
> possible.
You specifically went looking for trouble, and found it. Yawn.
Under normal operating conditions one would not repeatedly discharge
the cell to precisely the problem level and then recharge. Also, this
is one cell type and one operating condition. Other cells may or may
not have this characteristic, or may at a different discharge point.
It goes into the "don't do that *again*" basket.
Sure, I know that and you know that. ...but that's not what the non-
technical people call it. Whatever happens to reduce a NiCd or NiMH
cell capacity is "memory".
> not every cell
> > shows even this.
No, you have a cell type that is known (it's manufacturer tells you) to
exhibit this phenomenon. If it hurts when you do that, don't do it
again.
Try the specific discharge/charge profile for another manufacturer's
cell. You'll likely find a big difference. Cells are optimized for
different things. Perhaps Sanyo didn't see this as a major issue and
went for maximum capacity (or some such) accepting the "memory" at a
repeated specific discharge.
Why? The manufacturer said that it was a problem. You're simply
verifying the datasheet. In my book, that rates a "yawn". OTOH, your
statement about fully recovering after one complete discharge is
interesting.
That would be interesting. Now you're gathering information perhaps
not available in the datasheets. Try it on other manufacturer's cells
and the results could be quite interesting.
Want to share your charger/discharger design?
Keith
Dave VanHorn
Guest
Posts: n/a
      01-19-2004, 06:53 PM
Actually, you do, in many devices.
Pretty much anything with electronics in it, is going to have a shutdown
point.
If the device was designed for alkalines, but you're using NIMH in it, then
the shutdown point will be wrong, and result in short cycles like this.
> Also, this is one cell type and one operating condition.
Granted, more data as I have time to collect it.
I will.
to
Because they give no guidance on the magnitude of the problem.
It helps a lot to know when a limit is a brick, or a rubber wall.
All it takes is time.
up,
I can share the discharge/monitor stuff.
The charger is proprietary, but isn't really relevant to this. It was just
what was convenient to use. I've turned off a number of it's interesting
features for this test, so it's very vanilla, though it still senses end of
charge very nicely.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
Memory , I/O, Memory-I/O and I/O-Memory Mapping KBG CAD 2 12-17-2006 09:33 PM
Compton effect is a Doppler effect h_v_ansari@yahoo.com Electronic Basics 2 10-08-2006 01:18 PM
Compton effect is a Doppler effect h_v_ansari@yahoo.com Misc Electronics 1 10-08-2006 03:08 AM
Laptop battery Memory effect Weinberger Hans Electronic Design 19 03-22-2006 12:01 PM
Sealed Lead Batteries: do they suffer from "memory effect"? void@no.spam.com Misc Electronics 2 04-01-2005 02:03 PM
