Electronics Forums
Electronics Forums > Newsgroups > Electronics Newsgroups > Electronic Equipment > Need thin coax cables for HP 16515A/16516A timing cards
Reply
Thread Tools Display Modes
Rashid
Guest
Posts: n/a
      07-23-2006, 04:26 PM
2 thin coax cables that run from the card(s) have died and I am looking
for replacement.
May be some1 has a fried card etc ?
The cables, being so thin, are rather fragile, especially the tiny
(ceramic) board they have at the very ends - these can crack easily.
I checked the inputs on the board itself and those are fine, definitely
dead cables.
Alternatively, if someone wants to trade, I have a spare 35Mhz
state/100Mhz
timing module for 16500(a/b/c) frames.
Rashid
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
Can a coax connection be partially damaged? Some stations suddenly not coming in on HDTV on coax in. Doc Electronic Repair 8 11-30-2006 01:11 AM
Re: OT: Combined Electrical and Coax Outlet - TV-Outlet+Coax.JPG Rich Grise, Plainclothes Hippie Electronic Design 0 10-16-2005 10:45 PM
Looking for very thin (1mm) coax wire Andrew Sarangan General Electronics 5 12-06-2004 06:33 PM
Newbie: Datasheet timing diagrams and timing variation Richard Electronic Design 2 11-29-2004 11:29 PM
Need help with S/PDIF splitter - Coax -> Coax + Optical Itai Tavor Electronic Design 2 11-23-2003 11:18 PM
