Electronics Forums
Electronics Forums > Newsgroups > Electronics Newsgroups > Electronic Components > Need IC to a projector ballast
Reply
Thread Tools Display Modes
Mike
Guest
Posts: n/a
      03-06-2004, 05:51 PM
I probably wont get an answere to this one either,
but.
I am repairing a sharp XG-E850U movie/computer LCD projector.
The ballast crapped out.
I am working on the ballast, and when the unit powers up, you can hear the
SMPS inside the ballast start up, or the high freq pulse.
But, the ballast will NOT pulse the bulb, and the open circuit volage on the
bulb is 0v. it will pulse to 2v and back to 0 when you first turn on the
projo.
The heatsink, when left on for a minute, will get too hot to touch.
IC1702, which has an odd number of 10T45 is the culprit of overheating the
heatsink, and the thermal relay will kick in, and shut down the ballast.
IC1702 drives the bulb's transformer. and I need a cross to the 10T45 IC.
Its probably a mosfet in a packege, but I need either a cross, or a pinout
of the IC.
The number on the board is K837IDE
The bulb is good, because it was tested in a friends projector.
Any Ideas? The 300+vdc source is on the ballast.
I need the cross to IC1702, 10T45
Jerry G.
Guest
Posts: n/a
      03-07-2004, 05:20 PM
The part is Sharp only. They will sell only the complete circuit board or
module if it is still available, not the IC alone.
Greetings,
Jerry Greenberg GLG Technologies GLG
WebPage http://www.zoom-one.com
Electronics http://www.zoom-one.com/electron.htm
"Mike" <(E-Mail Removed)> wrote in message
news:r4p2c.2$(E-Mail Removed)...
but.
projo.
of the IC.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
Sharp XG NV33XE projector ballast jango2 Electronic Repair 0 08-11-2006 08:25 AM
Sharp XG NV33XE projector ballast jango2 Electronic Repair 0 08-11-2006 08:24 AM
LCD projector Hitachi CP-X275 lamp ballast repair tech tip Chris Goulet Electronic Repair 1 11-22-2005 05:28 PM
Need IC for projector ballast Mike Electronic Components 2 03-07-2004 02:42 PM
LCD projector ballast fried. Mike Electronic Repair 3 02-07-2004 10:13 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93
