How much current are you switching?
Too often, the ringing is blamed on the Inductive load, when the truth is that the ringing
is actually caused by the Inductance of the DC Link at turn off.
(DC Link refers to the input side DC voltage to the switch.)
Think of it this way, when you turn off the current, the commutating Diode of the device sends the power back to the input capacitors.
If you have high Inductance, both in the wiring and capacitors themselves, you will see
large spikes at turn off.
No snubber in the world is going to help that!
I switch 600VDC through IGBT H-Bridges at over 2000 Amps. It took me a year to discover that the spikes weren't from the transformer. I tried every snubber combination you could imagine, but still had spikes reaching 1200V or more.
When I got rid of the Litz Wires, and went to a laminated Buss, the spikes practically dissapeared! And finding capacitors with much lower inductance removed the problem altogether.
Can you provide photos of the input capacitors, and the wiring to the device?
I would bet I can provide some solutions to solve the problem.
