Electronics Forums
Electronics Forums > Members Area > Off-Topic Members Lounge > Need Help!!
Reply
Junior Member
      10-13-2010, 02:47 PM
I need help!! trying to detect if a electronic surveillance device is operative, if so how can I jamm it or trace it please help?
Super Moderator
(*steve*)'s Avatar
Location: Mid way between Beijing and the the Ronne Ice Shelf (mind your projection) ...and don't call me Sir!
      10-13-2010, 03:31 PM
The problem is, that if the XXXXXXXXX are really bugging you, they will be able to XXXXXXXXX XXXXXX the internet via a XXXXX XXXXXXXXX XX XXXXXX.
Your only option is to go to XXXXXXXXXX and get a XXXXX XXXX kit. That will allow you to XXXXXXX and XXX XXXXXXX that may be present.
Super Moderator
(*steve*)'s Avatar
      10-14-2010, 01:15 AM
Based on your private message, my answer is "smash it with a hammer"
Senior Member
Location: If a train leaves Australia for Hawaii... keep going.
      10-14-2010, 09:38 PM
You can always try covering the walls/floor/ceiling entirely with tin foil first, no?
Senior Member
      10-17-2010, 03:20 AM
Backwards "caveman" solutions - I soved the same problem by covering my Tilly hat inside and out, with tinfoil!
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
Empirical Beliefs & Hypothesis; Do they terminate in some beliefsthat need no further justification, go on infinitely - on belief beingjustified by other that then need justification, or circle back upon itselfin some way - constituting a sort of Immortalist Electronic Basics 31 08-24-2008 06:35 AM
Re: NEED HELP PIC12F629 need to compile for different MCU donald Electronic Design 1 12-20-2007 04:34 PM
Re: Need a circuit for a simple square wave generator with the least amount of onboard components, also need a current monitor.. Alan Rutlidge Hobby Electronics 0 10-02-2005 04:58 AM
Need to design precision 5mA constant current source (wide temp range).. need help stevo Electronic Basics 5 11-23-2004 04:56 PM
Need to transmit 38khz modulated IR signal, what's easiest way. Was: Need a 38khz pulse, is there anything better than using a 555? Bob Business Electronic Basics 1 11-19-2003 04:30 AM
