On Sat, 5 Jan 2008 16:54:53 -0800 (PST), "Dave.H"
<(E-Mail Removed)> wrote:
>On Jan 6, 12:27 am, "Dave.H" <the19...@googlemail.com> wrote:
>> On Jan 5, 11:45 pm, "Richard Seriani" <richard_s...@cox.net> wrote:
>> > Dave,
>> > Did you try Google?
>> > Here is one hit that may help, there were many others:http://www.lamptech.co.uk/Spec%20Sheets/GE%20NE45.htm
>> > Richard
>> So this NE-45 lamp only requires about 82k resistance for 240 volts?
>What contact is the internal resistor tied to, the side contact or the
>bottom contact? Also not too sure if 82k is right for 240 volt
>operation.
Doesn't matter which side the internal resistor is on (unless you are
doing something strange with the bulb, in which case you will have to
determine that experimentally).
The data sheet says to use an 82K for 240 volts, so it seems that that
is an appropriate value. However, if the lamp really draws 2 mA, 82 K
will drop 164 volts, which seems a bit much to me, so I might reduce
the resistor to 68K or so (to drop around 120V) if I needed a bit more
light.
Peter Bennett, VE7CEI
peterbb4 (at) interchange.ubc.ca
GPS and NMEA info:
http://vancouver-webpages.com/peter
Vancouver Power Squadron:
http://vancouver.powersquadron.ca
