Thanks Jackorocko and Ian
I will post more images as I get the chance
@ Ian, yes I know that problem Ian, I did attempt a little astronomy from an apartment balcony some years back with my original, 8" Dobsonian scope from the inner suburbs of Sydney. VERY trying conditions !!
Still live in Sydney but in a stand alone home so have a bit of a back yard to be able to move the scope around. Still a very bright sky, you can almost read the newspaper outside at nite
Ian, as far as buying a scope goes, what to get, depends on your intended use..
mainly visual observing, visual and photography or serious photography.
And really the sky's the limit in gear available and the prices can get ASTRONOMICAL !!! hahaha pun intended
but seriously for a scope that you can do good observing and some astrophotography work something like my new one will be great. Dont know when yoour planned move of location is ? maybe it will give you time to start saving a bit
If your planned new loc is a respectable dark site and you will only use the scope from home then you could look at anything from an 8" to a 12" diameter mirrored scope. But if like me and you need to regularly travel to a dark site, then you need a scope that can be moved without breaking your back and will fit easily into your vehicle. So a 8 or 9" scope is a fair size limit. That scope of mine is fairly heavy the main scope/fork mount section is 26kg, the tripod another 18kg. But it will fit into my little Toyota Echo hatch
If all you ever wanted top do was visual observing, you could get a decent Dobsonian mount scope again 8 - 12" and it would set you back ~ AU$500-600 for an 8" and up to maybe AU $1200 for a 12" scope. They would be Newtonian type optical setup.
But if you want to consider astrophotography then you really have no choice to spend signif funds and get something similar to mine. Its going to be motorised with tracking ability and you are going to start at ~ AU$2500 and upwards from there.
As winter approaches and the nites get longer I will look forward to going out to some darker sky sites out of the city and having some serious fun
No nebula pics yet Ian, definately need a dark site for that, can only see 2 or 3 of the really brightest ones fom home, like M42 in Orion.
Before I forget ..... If you have a bit of an interest or full on interest in astronomy. There is a nice software package (FREE) available for download Stellarium
http://www.stellarium.org/
and choose you OS from the top right list.
I put it on my laptop so I can take it out beside me at the scope. Set it up for your location, time zone etc and go for it.
ok enough waffle for this post
any Q's just ask
cheers
