Dimmer circuits, as simple as they look, the design and part values can
be a bit critical. But, if your dimmer circuit is actually okay, then
you have to investigate the load.
Some of these reading lamps use a small transformer inside. This is to
step the mains voltage down for a small type of reading bulb.
You cannot run a transformer or reactive device on a simple thyristor
dimmer. If so, the transformer may either burn out the dimmer, or be
damaged. This has to do with a number of complex reasons which is
really beyond what I can get in to over an email.
Greetings,
Jerry Greenberg GLG Technologies GLG
WebPage
http://www.zoom-one.com
Electronics
http://www.zoom-one.com/electron.htm
Instruments
http://www.zoom-one.com/glgtech.htm
"Wdyorchid" <(E-Mail Removed)> wrote in message
news:(E-Mail Removed)...
I'd been destroying dimmers on a handful. I'd been making homemade
dimmer
control (from ordinary residential dimmers) for my reading lamp. (Don't
know if
this violates safety codes.) I would plug the dimmer to the wall
receptacle
outlet and then plug the lamp into the dimmer. It's a handy device I
carry
around the house to any reading corner.
But the problem is that sometime while plugging the dimmer
into the
wall (with the lamp turned on) the dimmer tends for fail (or turn on at
full).
The dimmer is then discarded. The dimmer's death come at the same time
as I
noticed an arch inside the wall outlet while attempting to plug it in.
It's
probably not design for this since an aftermarket lamp dimmer I also
have won't
fail in any abusive condition. My homemade dimmers have a problem I have
no
solutions for and like to solve it. Any suggestions?
Why am I making homade lamp dimmers? A friend gave me a shoe-box half
full of
used dimmers.
-w orchid
