"Robert11" <(E-Mail Removed)> wrote in message
news:nqadnaJpoLys2GTfRVn-(E-Mail Removed)...
> Hi,
> Thanks for info.
> Can you recommend a point of use type of brand and model ?
> Want to protect a new furnace circuit board that runs off a dedicated 110
V
> line.
> Has already been fried once, recently, in a lightning storm.
> It has a fuse, but have real doubts if the board has any MOV's.
> What do yo think of the Intermatic AG2401 ?
First off absolutely nothing is lightning proof. The closer the lightning
gets the worse the results.
Second just protecting the furnance board is silly to my way of thinking.
( lets not go there right now )
IEEE says if your going to protect from Transients, and that may or may not
include lightning for some. It does for me. You need two of the three
levels of protected.
Levels are distribution, service, and point of use. Distribution would have
the highest let through service lower and point of use even lower.
Coordinating the zones is the key. Your situation installing the intermatic
at the service gives you one level of protection. You still need another
level that can withstand the 490v and clamp down further.
What is the voltage tolerance of the equipment being damaged? Furnance
boards are usually powered by a transformer not line power. I have not
worked on any of the new stuff but I think that the manufactures still keep
below 120v level for controls. Following this line the voltage was induced
into all of the wiring in your home. Only the furnance was damaged. I lost
a garage door opener last monsoon season, it was the only electronics, THEN,
that was not protected by a point of use TVSS.
Someone mentioned that the 490v clamping voltage seemed high. I tend to
agree. But this unit is being sold as a lightning protector. Just looking
at the voltage is not the whole story, you also need to look at the joules
that the unit will withstand/protect.
As a matter of prinicpal I do not care for "wired" solutions. I once worked
for an OEM, CH. They came out with a bus connection TVSS series called
Clipper. Yep they make wired solutions as well. Just like all of the other
manufactures. The techy's that I worked around explained to me that TVSS
connected to the bus are better cause the distance is shorter. Wired
connections are longer. Programs with the APQA, Arizona Power Quality
Association also agree with this.
My recommendation is to look for a bus connected surge protector/tvss by
your panel manufacture. As far as I know they all make them. Then look for a
point of use device
http://www.levitonproducts.com/catal...oogle&ovtac=PI
this one is a pretty blue color. (humor)
The bus connected unit should have a failure light, not that they are a
guarntee.
Nothing is lightning proof. Mov's are not tested for a second surge. I
replace my equipment everyother year.
good luck
========snipped=======================
