> I would also like a multimeter for general use (checking power supplies
> are still behaving, and so on).
Try the following link for a ATX POWER TESTER...
http://www.dansdata.com/quickshot018.htm
Sharpy
"Robert Downes" <(E-Mail Removed)> wrote in message
news:40453127$0$1157$(E-Mail Removed). ..
> Out of curiosity (and so I can tell whether the bigger power supplies
> are actually necessary next time I built a machine) I would like to
> measure how much power my PC is currently using, e.g. during 3D games
> that place demand on the 3D card, etc.
> Can a cheap clamp meter do both? I'm under the impression that a clamp
> meter for active appliance measurments really needs to be "True RMS"
> (because of distortion introduced by noisy drives). But is it possible
> to measure power by measuring the voltage on the power cord, then
> measuring current at different times? Or would the voltage change
> significantly as the demand changed, making current-only calculations
> useless?
> Can a clamp meter perform the same tasks as a standard digital
> multimeter (assuming you have test leads with it)?
> Basically, is it possible to closely (within 10% of true power
> requirement) measure and calculate appliance power use with only a
> standard (well, True RMS) clamp meter, or would the full-whack,
> expensive "Clamp-on Power Meter" be required to do this?
> Thanks for any advice you can offer.
> Bob
> London, UK
> echo Mail fefsensmrrjyaheeoceoq\! | tr "jefroq\!" "@obe.uk"
