Electronics Forums
Electronics Forums > Newsgroups > Electronics Newsgroups > CAD > Market for a GenCad .CAD to .DXF convertor?
Reply
Thread Tools Display Modes
Owen Ransen
Guest
Posts: n/a
      03-20-2008, 04:39 PM
Is there a market for a GenCad .CAD to .DXF convertor?
I've been asked to do a custom job to create a
a GenCad .CAD to DXF convertor...in your opinions
would there be a market for this in general?
Easy to use graphics effects:
http://www.ransen.com/
sycochkn
Guest
Posts: n/a
      03-21-2008, 05:27 AM
"Owen Ransen" <(E-Mail Removed)> wrote in message
news:(E-Mail Removed)...
What is the general use of a DXF file in electronic cad applications?
Owen Ransen
Guest
Posts: n/a
      03-21-2008, 06:04 AM
On Thu, 20 Mar 2008 22:27:37 -0700, "sycochkn"
>news:(E-Mail Removed).. .
As I understand it the use would be in production, not in the actual
design phase.
Brad Velander
Guest
Posts: n/a
      03-22-2008, 05:28 AM
Typically DXF files are only used for transfer of ECAD information to
mechanical CAD or alternate ECAD tools where there is no other transfer
facility/format.
As for the conversion of GenCAD to DXF, GenCAD is universally poorly
accepted. It is much less accepted than ODB++. Now the IPC talks about a
newer version of GenCAD, they just don't learn. The new version will
probably be panned by most tools/users also.
Sincerely,
Brad Velander.
"sycochkn" <(E-Mail Removed)> wrote in message
> Bob
sycochkn
Guest
Posts: n/a
      03-22-2008, 07:21 AM
"Brad Velander" <(E-Mail Removed)> wrote in message
news:HN0Fj.104772$w94.49534@pd7urf2no...
> facility/format.
> Sincerely,
> Brad Velander.
>> Bob
I was thinking of using dxf files to transfer Gerber files to AutoCAD and
using a component library for the parts. I see no real use for Inventor or
Solid Works, at the moment.
Leon
Guest
Posts: n/a
      03-22-2008, 03:21 PM
On Mar 22, 8:21*am, "sycochkn" <sycoc...@earthlink.net> wrote:
> "Brad Velander" <bvel...@SpamThis.com> wrote in message
> > facility/format.
> > * *As for the conversion of GenCAD to DXF, GenCAD is universally poorly
> > Sincerely,
> > Brad Velander.
> > "sycochkn" <sycoc...@earthlink.net> wrote in message
> >> "Owen Ransen" <wi...@wonker.com> wrote in message
> >>news:(E-Mail Removed). ..
> >> Bob
> I was thinking of using dxf files to transfer Gerber files to AutoCAD *and
> Bob- Hide quoted text -
> - Show quoted text -
The Pulsonix software I use can import DXF or Gerber files and export
GenCAD files, FWIW. I don't know how well it works, though.
Leon
Owen Ransen
Guest
Posts: n/a
      03-24-2008, 04:52 PM
On Sat, 22 Mar 2008 08:21:40 -0700 (PDT), Leon
Pulsonix, thanks!
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
Market for a GenCad .CAD to .DXF convertor? Owen Ransen Misc Electronics 2 03-22-2008 11:04 AM
Market for a GenCad .CAD to .DXF convertor? Owen Ransen Electronic Components 1 03-22-2008 10:20 AM
Market for a GenCad .CAD to .DXF convertor? Owen Ransen Electronic Design 0 03-21-2008 06:09 AM
Converting from GenCAD to DXF? Owen Ransen Electronic Components 2 03-16-2008 05:44 PM
New ultracap on the market... how does this relate to the EV market? Coleston Electronic Design 6 05-26-2007 11:40 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33
