Electronics Forums
Electronics Forums > Newsgroups > Electronics Newsgroups > CAD > LTspice is only for windows
Reply
Thread Tools Display Modes
kubik
Guest
Posts: n/a
      08-08-2004, 03:00 PM
I need to use a circuit simulator under a linux O.S. I downloaded LTSpice
( Switcher-CAD III ) and i found a .exe file.
I ask: is there a linux version of LTSpice?
If not can i use LTSpice under wine and how i can do it?
Thanks in advance.
Mike Engelhardt
Guest
Posts: n/a
      08-08-2004, 03:24 PM
kubik,
> Thanks in advance.
Yes, that version of LTspice will run on Linux w/ WINE. Here is the
relavent part of the FAQ:
Q. Do you have a version of LTspice for Linux?
A. Not a separate edition, but it does run under
WINE. The program has been tested on Linux
RedHat 8.0 with WINE version 20030219.
Q. OK, I've never used WINE, how do I install that
on my Linux box?
A. 1. Check with www.winehq.com to find the current
version of WINE for your system. At the time
of this writing, for RedHat 8.0, this points
to http://mecano.gme.usherb.ca/~vberon/wine
2. Copy the appropriate .rpm file to your machine
and open it from nautilus.
3. Get the file swcadiii.exe from www.linear.com.
In an xterm, execute "wine swcadiii.exe" to
install LTspice.
4. There will now be a Linear Technology Logo on
your gnome desktop. Double click it to start
or type "wine scad3.exe" from an xterm to
start the program. That's it!
Q. The schematic fonts don't scale as smoothly under
WINE as Windows. Why is that?
A. WINE is doing the best best it can with the fonts
it finds. It will do better if you tell it how
to find the files arial.ttf and cour.ttf from
your Windows system.
Q. The PWL additional point editor doesn't look
right under WINE?
A. Try using the native Windows .dll from your
Windows system. The command line to then invoke
LTspice from WINE is:
wine -dll commctrl,comctl32=n scad3.exe.
Q. It seems LTspice is running slightly differently
under WINE/Linux than windows. Why is that?
A. LTspice detects whether or not it's running under
WINE. If so, it works around a few WINE issues.
You can force LTspice to think it's running under
WINE with the command line switch -wine. You can
force it to think it's not with the command line
switch -nowine in case you're interesting in
debugging WINE.
Q. Under Windows, LTspice extends the virtual
address space for waveform viewing to 64 bits.
Does that work under WINE?
A. Yes. It has been tested on waveform files over
5 Gigabytes in size.
Q. Under Linux, does it support unlimited component
count and depth of schematic hierarchy?
A. Yes. Opps, no. The maximum depth of hierarchy
is 64 levels but that limit is just there to
allow detection of infinite subcircuit recursion.
(Most "unlimited" SPICE's "limit" you to about 21
levels.) LTspice has no limit on node or
component count either per page or for the
entire circuit.
Q. Does cross-probing while simulation work with
those slick marching waveforms while running
under Linux?
A. Yes.
Q. So from what version on is LTspice supported
under WINE?
A. 2.01g.
--Mike
Ken Smith
Guest
Posts: n/a
      08-09-2004, 01:29 AM
I am running LTSpice 2.09j, Suse-8.1 and wine version 20040213.
Except for a nagging problem with the cursor when drawing wires, it
works just fine for what I need.
There are two problems that Mike could fix when he gets a spare minute.
(like that will ever happen)
(1)
On my machine, when drawing wires, the cursor does not undraw its self as
it moves. I have to zoom to force it to repaint.
(2)
Also on my machine, if you have a signal source from a wave file and also
write to another wave file, the sim runs very very slowly or in fact
hanges, I not sure which.
(E-Mail Removed) forging knowledge
Mike Engelhardt
Guest
Posts: n/a
      08-09-2004, 03:26 AM
Ken,
Could you verify that this happens in the current version(2.10z) and report
to the address on the Help=>About dialog box.(I never put that e-mail
in print anywhere else for spam reasons.) I'm not at my linux box
right now, but my memory tells me that at least the cursor problem
doesn't happen on Linux/WINE.
--Mike
"Ken Smith" <(E-Mail Removed)> wrote in message news:cf6k2b$ak6$(E-Mail Removed)...
> (1)
> (2)
Ken Smith
Guest
Posts: n/a
      08-09-2004, 08:06 PM
In article <h9CRc.2562$(E-Mail Removed)>,
Mike Engelhardt <(E-Mail Removed)> wrote:
>Ken,
You mean "doesn't happen on my Linux/WINE" I assume and yes I will do it
over the next day or two.
Stuart Brorson
Guest
Posts: n/a
      08-12-2004, 04:04 PM
kubik <(E-Mail Removed)> wrote:
: I need to use a circuit simulator under a linux O.S. I downloaded LTSpice
: ( Switcher-CAD III ) and i found a .exe file.
: I ask: is there a linux version of LTSpice?
: If not can i use LTSpice under wine and how i can do it?
LTSpice is wonderful & runs well under wine, as has already been
pointed out.
Since you are a Linux dude, you might want to check out ngspice, which
is a Linux-native, open-source version of classic SPICE 3f5:
http://sourceforge.net/projects/ngspice/
Grab the 15fixedRC2 version.
It is a "work in progress", meaning that it sometimes won't converge
when LTSpice will, and very occasionally exhibits other quirks.
Personally, I find it extremely useful as a complement to LTSpice,
particularly because I sometimes want to use a CLI interface to
SPICE, which LTSpice lacks (or I haven't found yet).
Stuart
Chaos Master
Guest
Posts: n/a
      08-13-2004, 04:22 AM
Stuart Brorson's info is within the message
<(E-Mail Removed)> at location sci.electronics.cad:
You can write netlists, save with .cir extensions and load them on LTspice.
I've used this to put netlists made by other simulators, in LTSpice.
[]s
Chaos Master®, posting from Brazil. REPLY TO GROUP!
MSN: wizard_of_yendor[@]hotmail[.]com http://marreka.no-ip.com
"How many UNIX admins does it take to change a light bulb?
R: 1. Please refer to 'man mknod'"
/* frank */
Guest
Posts: n/a
      08-25-2004, 12:52 PM
kubik ha detto questo sabato :
> Thanks in advance.
It's run very well under Wine
while P$pice under wine sucks....
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
Re: Get WinPatrol Plus for only 99 cents -- today only! Yvan Hall Security Alarms 0 02-04-2010 07:46 AM
Re: Windows 2000 => Windows XP Pro Upgrade Joerg Electronic Design 5 12-29-2009 05:16 AM
Re: Windows 2000 => Windows XP Pro Upgrade Spehro Pefhany Electronic Design 1 12-26-2009 09:00 AM
ASCII schematics from LTSpice Jonathan Kirwan Electronic Basics 8 09-14-2004 08:33 PM
Need help with LTSPICE library Joe Electronic Basics 0 08-13-2003 07:51 PM
