Electronics Forums
Electronics Forums > Newsgroups > Electronics Newsgroups > Electronic Repair > Looking for Power Switch - Optonica Amplifier SM-1515B
Reply
Thread Tools Display Modes
JohnC
Guest
Posts: n/a
      04-20-2008, 08:05 PM
Can someone recommend a source for a replacement power switch?
It is a toggle type snap switch for an Optonica SM-1515B stereo amp. Hole
spacing is 1-3/8 inch. 120V.
Picture:
http://home.everestkc.net/upperquad/...pSwitch002.jpg
Thank you.
John C.
Eeyore
Guest
Posts: n/a
      04-21-2008, 09:27 AM
> Picture:
You'll be lucky to find one of those without having to buy a thousand or so on
special order I reckon.
Graham
EADGBE
Guest
Posts: n/a
      04-21-2008, 11:54 AM
I am curious -- What's wrong with the switch?
It's such a simple component. Are the internal contacts burned or
worn?
Eeyore
Guest
Posts: n/a
      04-21-2008, 12:25 PM
> worn?
Most likely. As the contacts are not replaceable you need to find an
exact replacement and there lies the trouble.
Graham
Ian Jackson
Guest
Posts: n/a
      04-21-2008, 12:39 PM
In message <(E-Mail Removed)>, Eeyore
<(E-Mail Removed)> writes
>> worn?
>Graham
Need it be and 'exact' replacement? Maybe it's time for a bit of
creativity and improvisation?
Ian
EADGBE
Guest
Posts: n/a
      04-21-2008, 01:30 PM
On Apr 21, 8:25 am, Eeyore <rabbitsfriendsandrelati...@hotmail.com>
Would any SPST switch with an adequate voltage/current rating suffice
(presuming it fits where the old one did)?
Eeyore
Guest
Posts: n/a
      04-21-2008, 04:19 PM
Aside from the detail of fitting in the same hole, absolutely yes. Do
ensure you get a type suitable for *mains* switching.
Graham
FJ
Guest
Posts: n/a
      04-21-2008, 08:03 PM
"Eeyore" <(E-Mail Removed)> schreef in bericht
news:(E-Mail Removed)...
> Graham
Another viewpoint: Just permanently connect the wires (and apply proper
insulation), and switch the amp on and off with a correctly rated switch in
the mains lead.
Or, maybe even better, leave the amp powered-on.
The hole of the original switch can be filled either with the now
non-functional switch, or a nice power-on indicator. Add some creativity
here ;-)
YMMV, Folkert/NL
James Sweet
Guest
Posts: n/a
      04-21-2008, 08:16 PM
> in the mains lead.
> here ;-)
> YMMV, Folkert/NL
That's ghetto, much better to fix it right, you might be able to disassemble
the switch and repair the contacts.
Why would it be better to leave the amp on all the time wasting energy? That
stuff isn't free.
JohnC
Guest
Posts: n/a
      04-22-2008, 12:48 AM
I appreciate the comments and suggestions.
The switch that needs replacement is actually fine electronically. In fact
it is always on. The problem is with the snap action mechanism. The switch
lever took a blow to the side and broke some key plastic rocker parts that
allow the snap action to function. Any SPST switch rated at 120V, 1 amp?
will work but my preference is to maintain the cosmetics. Switch should be
OFF in the down position and ON in the horizontal. I thought this flat lever
switch was fairly common but perhaps I was mistaken.
I viewed some of the recommended sites but came up negative.
John C.
"Arny Krueger" <(E-Mail Removed)> wrote in message
news:(E-Mail Removed). ..
> "JohnC" <(E-Mail Removed)> wrote in message
> news:c892$480ba1fb$40971c7d$(E-Mail Removed)
>> switch?
>> stereo amp. Hole spacing is 1-3/8 inch. 120V.
> Looks to me like a fairly generic paddle switch.
>> Picture:
> It was probably marketed under the brand name "Panasonic". It may be a
> stock design.
> If you're looking for an exact replacement, here are some places to look:
> (1) Authorized parts sellers for the brand of equipment you are trying to
> repair.
> (2) Distributors for the brand of part, in this case Panasonic.
> If you're looking for an near replacement, here are some places to look:
> (1) Electronic parts catalogs for places like Newark, Digi-Key, and
> Mouser.
> (2) Surplus and remainering houses like Jameco, All Electronics and Parts
> Express.
> You are looking for a part with the same number or more contacts, with
> contacts rated at the same or more amps and volts, and one that is the
> same size or smaller. Mounting centers should match or be smaller.
> Your replacement strategy may include fabricating a sheet metal bracket
> that bridges any possible gaps.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
Looking For Data On Dreefs Rocker Switch, Looking for data sheet dxpwny Datasheets, Schematics, Manuals and Parts 1 12-04-2011 08:54 AM
The power switch of Technics sterio integrated amplifier SU2500 is broken poweredforce Electronics Repair 1 09-10-2011 10:55 PM
Looking for this switch (Midas Venice solo switch) Eeyore Electronic Components 30 09-10-2008 11:24 AM
Looking for this switch (Midas Venice solo switch) Eeyore Electronic Repair 29 09-10-2008 11:24 AM
Looking for Power Switch - Optonica Amplifier SM-1515B JohnC Misc Electronics 9 04-22-2008 12:48 AM
