On Fri, 07 Nov 2003 14:25:03 -0700, the renowned mikem
<(E-Mail Removed)> wrote:
>I need to measure the position of an object which moves slowly (< 1Hz)
>along one axis. Max travel is about 6 inches. I want to read its
>position to a resolution about 1 part out of 1024 (10 bits), but the
>absolute accuracy only needs to be 1%. I can mechanically attach
>something like a pushrod to the object.
>I'm familiar with LVDTs and the old NE5521 chip, but dont want to
>spend a $1000 for a 6" LVDT.
How much life do you need? A linear conductive plastic pot might do
the trick.
Best regards,
Spehro Pefhany
"it's the network..." "The Journey is the reward"
(E-Mail Removed) Info for manufacturers:
http://www.trexon.com
Embedded software/hardware/analog Info for designers:
http://www.speff.com
