Electronics Forums
Electronics Forums > Newsgroups > Electronics Newsgroups > Electronic Repair > Industrial Sewing Machine motor brushes - Sandor Corp manf
Reply
Thread Tools Display Modes
Margecam52
Guest
Posts: n/a
      06-28-2006, 10:38 PM
Hope someone here can be of help. I have a motor that needs the carbon
brushes replaced but can't find parts or anyone willing to repair it.
Looks like a fairly easy replacement (couple solder joins) if I can
find parts. I need the brushes for this model. Brushes are 7/8 or 1
inch long by 1/4 in (h & w). The connector is on the side of the long
portion, toward the back. The copper wire is about 1 " long or so.
There is a number on the brush that is not broken, and it's a 608 or
908, can't tell.
I need to get the part(s) and get sewing..can't find anywhere & don't
want to buy an entire motor.
Second Question..just in case, would a 1/2 hp Singer sewing machine
motor work as replacement..same rpm & voltage. The current motor goes
counter clockwise, and the Singer is reversable.
The motor is labeled:
Nustyle (machine brandname)
90 VDC
RED? POS FOR CCWSE
Model 1(?)70-210 021
Sandor Corp (now Leeson) Sedalia MO
Model number first diget very faded, think it's a 1
I put photos of the parts & motor at:
http://community.webshots.com/myphot...5216&ran=10170
Can also email to you. The above allows for a bit larger photo than I
can send email
I am confident enough to replace the brushes..they look to be able to
be replaced without having to disturb the solder, if not..soldering
should not be hard (have soldering iron for stained glass).
If you know where I can get the parts, would be great, the manufacturer
has not replied.
Thanks for trying to help
Marge
Ken Layton
Guest
Posts: n/a
      06-28-2006, 11:55 PM
Some of the Ace Hardware stores sell motor brushes back in the
hardware/nuts/bolts section in those pull out drawers.
Margecam52
Guest
Posts: n/a
      06-29-2006, 04:48 AM
Thanks that was going to be my first stop tomorrow. We don't have a
lot of stores in Littlefield, but there is an Ace down the road..and
one electrical shop.
Would you know if I find brushes the correct size, but with different
config on wire placement.. if it would matter as long as I can connect
them?
Marge
catguy
Guest
Posts: n/a
      06-29-2006, 06:31 AM
"Margecam52" <(E-Mail Removed)> wrote in message
news:(E-Mail Removed) ups.com...
> them?
> Marge
How about McMastercarr pn 65705K51........Paul
http://www.mcmaster.com/
Dave Plowman (News)
Guest
Posts: n/a
      06-29-2006, 09:06 AM
In article <(E-Mail Removed). com>,
> them?
I'd go about it the other way round - find ones oversize with the correct
springs. They're only carbon, and easy to shape to size. Put some fine
abrasive sheet - sandpaper even - on a glass sheet or other flat surface
and rub the brush on it until the correct dimensions are obtained.
*Whatever kind of look you were going for, you missed.
Dave Plowman (E-Mail Removed) London SW
To e-mail, change noise into sound.
Margecam52
Guest
Posts: n/a
      06-29-2006, 01:34 PM
Thanks... ordered a set just in case the motor I got on ebay will not
fit. I'll also be going to my local Ace hardware when they open...
would like to use machine today. Have several quilts that need to get
finished.
You all (guess I should say Youawl) have been a big help.
Marge Campbell
Littlefield TX
Margecam52
Guest
Posts: n/a
      06-29-2006, 01:36 PM
This is what I was wondering... I'll find some that are close and
resize them. Marge
default
Guest
Posts: n/a
      06-30-2006, 12:35 PM
On Thu, 29 Jun 2006 09:06:38 +0100, "Dave Plowman (News)"
>> them?
That works like a champ. The spring and connecting wire are more
important than the size - I use a fine cut bastard file to take them
to size.
If you use sandpaper, avoid getting abrasive particles in the
commutator -
----== Posted via Newsfeeds.Com - Unlimited-Unrestricted-Secure Usenet News==----
http://www.newsfeeds.com The #1 Newsgroup Service in the World! 120,000+ Newsgroups
----= East and West-Coast Server Farms - Total Privacy via Encryption =----
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
Old Singer Sewing Machine - No Variable Speed pxbacher@gmail.com Electronic Repair 8 04-24-2009 06:45 PM
Small Motor Carbon Brushes jadney@vwtype3.org Electronic Repair 4 03-27-2007 03:39 PM
Janome Memory Craft 8000 sewing machine problem David Electronic Repair 1 12-10-2005 10:17 PM
Longevity of Carbon Motor Brushes Chris F. Electronic Repair 4 09-05-2004 10:59 PM
Sony TC 770 motor brushes need. jandree Electronic Repair 0 07-25-2004 07:45 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33
