Electronics Forums
Electronics Forums > Electronics Forums > Circuit Help > ICM7556 Monostable Touch Switch doesnt work
Reply
Thread Tools Display Modes
Junior Member
      02-03-2012, 01:17 AM
I have a touch-activated circuit (5V power source) that works fine with an NE556 chip, driving the Output up for about 8 seconds (timing circuit consists of a 4.7microfarad cap and 1.5M resistor), driving an NPN transistor that powers an LED (see attached circuit). As a monostable circuit, after 8 seconds the Output drops to 0V until I ground the Trigger again. When I replace the NE556 chip with the low power CMOS ICM7556 (this circuit will run on a battery and I need to draw as little current as possible), the Output stays high for the 8 seconds, and then after a barely visible drop in voltage (Voltmeter hardly moves) Output goes high again, acting like it's an astable instead of monostable circuit.
I understand that CMOS versions are much more sensitive, and I am wondering if the circuit is being activated by a stray signal, etc. I am currently only using one of the 556 timers, and read somewhere that maybe the open pins on the second timing circuit could be interfering with the first circuit.
I imagine it is my lack of electronics experience (especially with CMOS devices) that is the main culprit, but any help in figuring out how to get the ICM7556 to act like a "normal" 556 would be most appreciated!
Senior Member
Raven Luni's Avatar
      02-03-2012, 02:02 AM
The most obvious things that stand out are the resistor values. 220K is way too high for the transistor especially if the signal is coming from a low current device like a 7556. Try something lower maybe about 10K. You could also increase the 4.7uF capacitor and decrease the 1.5M resistor to get the same RC time constant.
Finally, its always good practice to ground the control pin through a 10nF capacitor.
Edit: You might also want to move the LED to the collector side of the transistor. I'm not sure what effect having a voltage drop between emitter and ground would have.
There must be a relationship between zombies and work. One eats your brain, the other eats your soul.
Super Moderator
(*steve*)'s Avatar
Location: Mid way between Beijing and the the Ronne Ice Shelf (mind your projection) ...and don't call me Sir!
Send a message via Skype™ to (*steve*)
      02-03-2012, 02:27 AM
There is also no resistor in the discharge path. Discharging a 4.7uF capacitor repeatedly through the device will probably destroy it.
Senior Member
      02-03-2012, 07:33 PM
The trigger input should be pulled high via a 10K or so resistor. Otherwise it is floating when you don't ground it.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
Sony HCD-H5 / CD-player doesnt work Rhadez Electronic Repair 1 09-07-2005 06:31 PM
re:Sony HCD-H5 / CD-player doesnt work Rhadez Electronic Repair 1 09-07-2005 06:27 PM
re:Sony HCD-H5 / CD-player doesnt work Rhadez Electronic Repair 0 09-07-2005 04:36 PM
Old philips FA156 doesnt work Worner Electronic Repair 0 02-13-2005 01:05 AM
Panasonic CTN-2056S Convergence off - serviceman mode doesnt work Eric Electronic Repair 6 01-09-2005 04:49 AM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98
