Electronics Forums
Electronics Forums > Newsgroups > Electronics Newsgroups > Electronic Basics > Homemade cat5 cable using existing phone line fails.
Reply
Thread Tools Display Modes
Sam Nickaby
Guest
Posts: n/a
      03-11-2006, 10:41 AM
I made my own Ethernet cable to extend our DSL connections to
25 feet. I used a cat5 male connector on each end. I use two ordinary
phone line cords. After I lined them up identically like what cat5 cables
are supposed to I then solder and assemble the cords. I then check the
resistance on all eight terminals. They all check fine.
The problem is when I plug one end of the cable to DSL modem the other
to the PC the cable fails to work. I keep getting "network cable unplug" and
"network cable plug" consistently until I unplug the cable. Does this
mean that the cat5 won't accept the ordinary phone cables?
David Schwartz
Guest
Posts: n/a
      03-11-2006, 11:11 AM
"Sam Nickaby" <(E-Mail Removed)> wrote in message
newsPxQf.28581$(E-Mail Removed). com...
> and
> Thanks
To make a cat patch cord, you need to use cat 5 cable.
DS
Peter Kolbe
Guest
Posts: n/a
      03-11-2006, 11:15 AM
Pins 1 and 2 must be on one twisted pair
Pins 3 and 6 must be on another twisted pair
If you do not have pairs that are twisted together all the way through the
cable, then you cannot use it.
If they are not grouped specifically on the pairs, then there will be
crosstalk, etc.
Peter
Robert Redelmeier
Guest
Posts: n/a
      03-11-2006, 03:14 PM
In comp.dcom.cabling Sam Nickaby <(E-Mail Removed)> wrote in part:
> I use two ordinary phone line cords.
This is usually flat silver satin. No-where close to Cat5.
Strictly speaking, Cat5 describes an end-to-end link quality
that should be certified. When components are marked "Cat5",
it means that the mfr believes that they can be used to make a
link that will pass Cat5 testing _iff_ you do everything right.
> After I lined them up identically like what cat5 cables are
> the resistance on all eight terminals. They all check fine.
Low resistance straight thru is not enough. Ethernet uses
differential signals which must travel on balanced twisted pairs
to avoid corruption. Electrons may be color blind, but they know
who their dance [twist] partners are.
-- Robert
Roy
Guest
Posts: n/a
      03-11-2006, 04:21 PM
> Thanks
Your cable is not CAT5 since it doesn't have the right number of twists
but then again you don't need CAT5. Your DSL modem probably runs at
10Mbps which calls for CAT3 cable. CAT3 has less twists and most telco
cable meets the criteria. The cable you have may be below that but it
might not matter for a the short run. YMMV
The link light would come on in any case so you have something else
wrong. Your modem may require a cross over cable or you don't have it
wired correctly (pin1 to pin1). You actually only needed two pair 1-2
and 3-6.
Correct that problem and then try your cable. If you don't get errors,
you are just fine
Roy
Carl Navarro
Guest
Posts: n/a
      03-11-2006, 04:30 PM
I'll feed the troll.
You don't want to know what I think you did.
Buy a long patch cord or call a professional or a better amateur.
Carl Navarro
petrus bitbyter
Guest
Posts: n/a
      03-11-2006, 05:19 PM
"Sam Nickaby" <(E-Mail Removed)> schreef in bericht
> and
> Thanks
Did the equipment run when using an original (shorter) cat5 cable? Did you
use the right pairs twisted? The colors of the ordinairy telco cable you
used may differ from the cat5 ones, you know. What about your soldering
skills? You measured for conductivity, did you also check for short circuit?
(BTW, all CAT5 connectors I'm aware of are crimp types, where did you get
these solderable things from? How do they look like?) Where did you get the
information of the cat5 cable? Be aware that real cat5 cable has a higher
quality and price that ordinary telco. The quality of your home industry
product may not be good enough.
petrus bitbyter
DecaturTxCowboy
Guest
Posts: n/a
      03-11-2006, 05:36 PM
At the risk of someone saying this thread is pathetic, I'll post an
answer as there are some good points to consider.
> 25 feet.
From what you are describing, it appears you have a simple DSL to
computer hookup. Instead of extending the ethernet connection from the
modem to the computer, why not simply place the modem next to the
computer and extend the silver satin phone line to the modem.
> phone line cords.
As other guys have said, silver satin line cord won't work. Untwisted
cable has no cross-talk immunity.
Typically CAT5 ethernet cable are straight-through, but
DSL modem-to-computer cables are usually cross-over.
Those error messages usually indicate intermittent loss of copper
continuity, even thought you are showing good continuity when you test
the cables, they may not work when plugged in. My line of thinking is
that you might be using modular plugs designed for solid conductor and
silver satin is stranded wire. Although is more problematic the other
way around - using a stranded wire modular connector with solid wire.
The error message "Local Area Connection is now connected. This
connection has limited or no connectivity" usually means you have an IP
issue, but there can be two reasons for this. You computer's TCP/IP
properties are set for dynamic IP, but your network is static IP *OR*
you simply can't connect due to a cable problem.
You may even get a message saying "Local Area Connection is now
connected. Speed: 100.0 Mbps" when in fact its not working as that
message only indicates you have copper continuity. I've seen this after
someone stapled 50 feet of CAT5 to the baseboard. No error messages, but
it just didn't work..period.
BTW...just for grins, I just made up a 20 foot silver satin cord with
568B modular ends for stranded cable. It said "Local Area Connection is
now connected. Speed: 100.0 Mbps", but I couldn't even ping the two
computers.
> Does this
Move the modem next to the computer and redo you ends with RJ-11 plugs.
Rich Grise
Guest
Posts: n/a
      03-11-2006, 07:14 PM
> Thanks
I've used cat 3 (ordinary flat telephone extension cable) for a 100' run,
with cat 5 (RJ-45) connectors at each end - but I had to pay attention
to which pins I hooked up:
http://www.ertyu.org/steven_nikkel/ethernetcables.html
I suspect you have a simple miswire, or I don't understand the question.
Good Luck!
Rich
DecaturTxCowboy
Guest
Posts: n/a
      03-11-2006, 08:36 PM
> Carl Navarro
Don't feel bad Sam. His posts seem to sarcastic replies indicate HE is
the one that needs to see a professional.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
AC Power filter and phone line filter (homemade circuit breaker) Emanuele Electronic Design 3 10-15-2008 03:47 PM
cat5 cable for RS485 and power ? john Electronic Design 16 03-29-2005 05:18 PM
cat5 cable tester b.a. marcus Electronic Components 7 01-09-2004 01:26 AM
Re: FA. double your phone line capacity and still use your single line phone gear, modem fax ansmwering machine amaz Marc H.Popek Electrical Engineering 0 09-28-2003 04:42 PM
FS [Perth] cat5 twisted pairs cable $3 each Cheers Hobby Electronics 0 07-07-2003 06:39 AM
