Electronics Forums
Electronics Forums > Newsgroups > Electronics Newsgroups > Electrical Engineering > High voltage arcing into water, colloidal silver.
Reply
Thread Tools Display Modes
fenceerex
Guest
Posts: n/a
      05-04-2004, 09:09 PM
I am experimenting with making HVAC colloidal silver.
One silver electrode submerged in the 1 quart beaker of distilled water.
Other silver electrode is one half inch above the water. An arc forms for
me. After half an hour I get a good ppm reading. Am I getting colloidal
silver in the water or am I getting nitrates in water from the arc?
With such arcing does the electrode get worn down over time? Does some
silver come off it? Or any other metal that would be used for such an arc.
Such as copper or iron?
(I am being very careful with all this)
Thanks much
Fens
You can also email me if you want. Remove the SPAMNOT and only the SPAMNOT
(E-Mail Removed)
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
high voltage safety to go with my high voltage projects electronboy Electronic Projects 1 07-25-2011 02:12 PM
IGBT dual high power, high frequency, high voltage switching units bernado Electronic Design 0 02-05-2007 05:10 AM
Arcing in a old 3-way switch! js5895 Electronic Basics 2 04-19-2005 11:14 PM
Colloidal silver generator? wrongaddress@att.net Electronic Design 89 04-11-2005 06:06 PM
arcing voltage? jack Electronic Basics 3 09-20-2003 12:09 PM
