Electronics Forums
Electronics Forums > Newsgroups > Electronics Newsgroups > Electronic Design > High or low side current sensing
Reply
Thread Tools Display Modes
Raveninghorde
Guest
Posts: n/a
      02-08-2010, 11:09 PM
I'm reviewing an existing charger design which I'm expanding to 10
outputs.
At the moment I use high side current sensing with an opamp and fet
level shifting the signal so that it is ground referred.
The disadvantage is that this circuit can not measure the current
during a short and relies on the swticher's own current limit for
protection.
I've used a current mirror circuit before to get around this but it's
too many parts.
If I low side sense then this problem disappears. But then I loose the
simplicity of a common ground.
I can't make my mind up. Time for a whisky.
Joerg
Guest
Posts: n/a
      02-08-2010, 11:34 PM
> outputs.
> protection.
> too many parts.
You could consider current monitor chips that have a helper voltage and
where common mode includes ground. But it's not as cheap. If each charge
channel has its own switcher, can't you sense current there?
Regards, Joerg
http://www.analogconsultants.com/
"gmail" domain blocked because of excessive spam.
Use another domain or send PM.
Joerg
Guest
Posts: n/a
      02-09-2010, 01:10 AM
>> outputs.
>> protection.
>> too many parts.
> Operate the sensing circuit from a separate supply that does not get
> effected from the main supply drop.
> In your circuit, I assume you're using the +/- inputs of the opamp to
> form a dif shift via a shunt R ? The op-amp and Fet you're using can be
> operating from a secondary supply that can also share the same common.
> of course, if you throttle back the drive using the current sense, you
> wouldn't get a total loss of voltage!.
If the battery terminals short out you do get a total loss of voltage.
But it's no big deal if there's a helper voltage that, for example,
provides a negative supply if the opamp CM range doesn't include VSS.
Regards, Joerg
Jamie
Guest
Posts: n/a
      02-09-2010, 01:27 AM
> outputs.
> protection.
> too many parts.
you wouldn't get a total loss of voltage!.
Adam Seychell
Guest
Posts: n/a
      02-09-2010, 07:26 AM
> outputs.
> protection.
> too many parts.
What are your desired current, voltage and measurement accuracy ?
Raveninghorde
Guest
Posts: n/a
      02-09-2010, 09:19 PM
On Mon, 8 Feb 2010 18:19:58 -0800 (PST), MooseFET <(E-Mail Removed)>
wrote:
>> outputs.
>> protection.
>> too many parts.
>How about:
> +-----------------/\/\---------+--!+\ ! s !
> ! ! ! ! --!! P-
>MOSFET
> -------+---/\/\---+----Battery(+) --/\/\-- !d
>+--/\/\--GND
> V =
>K*I
>It is the normal op-amp based constant current source but the op-amp
>doesn't have to take
>the large common mode and you don't need the 0.1% resistors.
>The down side is you needenough voltage for the op-amp.
Thanks.
That looks good and appears to get around the short circuit problem.
It adds 3 resistors to my component count. Under half a cent extra
component cost plus placement time.
Raveninghorde
Guest
Posts: n/a
      02-09-2010, 09:24 PM
On Tue, 09 Feb 2010 18:26:46 +1100, Adam Seychell
>> outputs.
>> protection.
>> too many parts.
I'm happy with 3% accuracy on current. Who cares if a battery charges
at 970mA rather than 1A.
I'm charging lithium ion so voltage is more important. On a 4 cell
pack I expect to be between 16.70V and 16.75V so that's +/- 0.15%
after adjustment.
Raveninghorde
Guest
Posts: n/a
      02-09-2010, 09:30 PM
On Mon, 08 Feb 2010 15:34:38 -0800, Joerg <(E-Mail Removed)>
>> outputs.
>> protection.
>> too many parts.
In this application I am using National simple switchers so they don't
help with the current measurement. They do provide an internal current
limit which does provide short circuit protection.
I don't like the short circuit current being higher than the charging
current. In the other job I've got to tidy up for production I'm
using a sepic which does need a proper current limit.
I like to use common building blocks and MooseFET's circuit looks good
at the moment.
Raveninghorde
Guest
Posts: n/a
      02-09-2010, 09:38 PM
On Tue, 9 Feb 2010 07:21:11 -0000, "TTman" <(E-Mail Removed)>
wrote:
>"Raveninghorde" <raveninghorde@invalid> wrote in message
>news:(E-Mail Removed).. .
>> outputs.
>> protection.
>> too many parts.
>Protect power on with 'battery good' detect first ?
I have battery good detection in the micro. The charger has to be safe
even if the micro dies.
The customer checks short circuit by putting a switch across the
output and a then a fuse in line to the battery. They then start
charging and throw the switch.
Similarly for reverse battery protection they fit a reversing switch
into the wiring. Again they start charging and throw the switch.
Joerg
Guest
Posts: n/a
      02-09-2010, 10:27 PM
>>> outputs.
>>> protection.
>>> too many parts.
On a SEPIC that's easy. You can sense the current at the base of the
second coil and run that into an inverting opamp.
> at the moment.
So you owe him a beer then :-)
Regards, Joerg
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
rec.models.rockets FAQ Part 00 - Introduction and TOC rmrfaq@n2netmail.com Rocketry 2 01-13-2010 06:35 AM
rec.models.rockets FAQ Part 00 - Introduction and TOC rmrfaq@n2netmail.com Rocketry 2 10-28-2009 05:28 AM
Transistors - making me ill Jon Electronic Basics 21 02-01-2004 03:49 AM
transformer phasing question phil-news-nospam@ipal.net Electronic Basics 6 01-23-2004 08:08 PM
Confused about "What is current flow" Brian Electronic Basics 13 09-04-2003 07:40 AM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33
