Electronics Forums
Electronics Forums > Newsgroups > Electronics Newsgroups > Electronic Design > Hey, what is all this 'off topic' posting?
Reply
Thread Tools Display Modes
Bob Monsen
Guest
Posts: n/a
      09-04-2005, 01:06 AM
I've noticed an alarming trend towards posts that are about electronics,
rather than politics or cooking.
Please, people, mark any electronics post with "OT", so we don't get
confused and start flame wars about the best capacitor or something like
that!
Regards,
Bob Monsen
If a little knowledge is dangerous, where is the man who has
so much as to be out of danger?
Thomas Henry Huxley, 1877
Rheilly Phoull
Guest
Posts: n/a
      09-04-2005, 01:16 AM
"Bob Monsen" <(E-Mail Removed)> wrote in message
news(E-Mail Removed)...
> that!
> Regards,
> Bob Monsen
I wouldnt be worried, its just a passing fad ya know.
Just killfile all the "electronics trolls" and they will go away.
Regards ......... Rheilly Phoull
Richard Crowley
Guest
Posts: n/a
      09-04-2005, 01:18 AM
"Rheilly Phoull" wrote ...
Indeed. Works great. Improves SNR of s.e.d by at least 40dB.
John Larkin
Guest
Posts: n/a
      09-04-2005, 05:48 AM
On Sat, 03 Sep 2005 18:06:51 -0700, Bob Monsen <(E-Mail Removed)>
I've been grinding out assembly code all week. There's nothing much to
say about that.
John
Pooh Bear
Guest
Posts: n/a
      09-04-2005, 06:30 AM
> say about that.
Might I ask why you're using assembler and what the CPU is ?
When there's a reasonably priced high level language alternative I really
don't see the point of using assembler.
Graham
p.s. I've used assembler where there was no alternative - audio DSP chip with
support only for assembler from the manufacturer.
redbelly
Guest
Posts: n/a
      09-04-2005, 12:27 PM
I wish the good people at Google would get off their arses and include
that feature in their newsgroup reader.
Mark
SioL
Guest
Posts: n/a
      09-04-2005, 01:21 PM
"Pooh Bear" <(E-Mail Removed)> wrote in message news:(E-Mail Removed)...
>> say about that.
> Graham
Here we go, another C versus ASM war.
I use AVR a lot and Atmel is forcing me into using C,
all new ANs are using C.
Than again, the bootloader in C is writing all over the SRAM
section of atmega screwing up my cunning memory backup
plan in process, even when it just checks the pin and jumps to
the reset vector.
With asm you always know what to expect, with C its a guessing
game.
Siol
Rather than a heartless beep
Or a rude error message,
See these simple words: "File not found."
Frank Bemelman
Guest
Posts: n/a
      09-04-2005, 02:01 PM
"SioL" <(E-Mail Removed)> schreef in bericht
news:eOCSe.66$(E-Mail Removed)...
Rewrite them in ASM if you must.
> the reset vector.
> game.
With asm you know you will need 10 times more time to deliver 1/10th
of the functionality. Use it for those two highly optimized loops
you need, but for all other stuff, forget it. It's 2005.
Thanks, Frank.
(remove 'q' and '.invalid' when replying by email)
Pooh Bear
Guest
Posts: n/a
      09-04-2005, 03:15 PM
> >> say about that.
> > Graham
Not at all. I'm no fan of C. I was actually offered a job coding in C back in 1984 - it was a publishing
application - long before Adobe got into that stuff - maybe long before Adobe even existed ! It was an inhouse
piece of software that took files from WordStar typically ! ;-)
I took one look at C code and syntax and 'ran away' - lol !
To this day I reckon that C / C+ / C++ is deliberately obscure so to as to impress the PHBs.
> the reset vector.
> game.
I like 8051s and their variants. I use PL/M 51. It's a lovely language to use but sadly Intel abandoned it. As
easy as Basic to understand but with the ability to talk to registers ( and indeed any other hardware you like
) directly if you need to. Not to mention some damn useful commands that are assembler-like such as ROL.
PL/M code is never obscure. It's quite the reverse.
And then there's the PL/M compiler's skill in using available free RAM to its best wrt to lifetime dependent
variables. I doubt any asm coder could match that !
Graham
Pooh Bear
Guest
Posts: n/a
      09-04-2005, 03:30 PM
> > the reset vector.
> > game.
I sometimes use the 'show code' function with PL/M to see what asm has been
generated by the compiler.
Invariably it produces code that's very efficient and I don't have to worry
about it.
Best example I've come across comes to mind. 8031 with 12MHz crystal.
Interrupt service routine needs to compare 2 x *16* bit numbers and return
a conditional result.
It took ~ 70 us including the vectoring in and out overhead.
Even better. I deliberately sent interrupts at greater than the interrupt
service routine's period. You might expect a 'lock-up'. Not so. Reduce the
interrupt rate and normal service is restored !
Now beat that hand coding in asm !
Graham
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
Help on Looser-Take-All / Winner-Take-All circuit Etantonio Electronic Design 2 03-17-2005 10:18 AM
Help on Looser-Take-All / Winner-Take-All circuit Etantonio Electronic Equipment 1 03-16-2005 08:18 AM
Help on Looser-Take-All / Winner-Take-All circuit Etantonio Electronic Basics 2 03-16-2005 07:17 AM
Help on Looser-Take-All / Winner-Take-All circuit Etantonio Electronic Components 0 03-15-2005 03:56 PM
Help on Looser-Take-All / Winner-Take-All circuit Etantonio CAD 0 03-15-2005 03:56 PM
