Electronics Forums
Electronics Forums > Newsgroups > Electronics Newsgroups > Electronic Repair > help needed: Panasonic monitor Panasync E70i 17" monitor
Reply
Thread Tools Display Modes
Aslaner
Guest
Posts: n/a
      10-09-2004, 02:37 AM
There is no adjustment on the horizontal width, all other controls OK,
monitor looks fine other than that.
I have done the cold joints, looked for bad caps, bad active components?
Has anyone solve one of these problems before, I fixed a Panasonic not that
long agao and it was a bipolar cap in the horizontal, this time the cap is
good?
Aslaner
Guest
Posts: n/a
      10-10-2004, 05:16 PM
Problem solved
After eliminating everything, like bad caps bad cold joint, bad active
components.
I found a resistor which was opened, R707 Brown/Grey/Yellow 180K
All is back to normal now.
"Aslaner" <(E-Mail Removed)> wrote in message
news:Z9I9d.37707$(E-Mail Removed) ...
> that long agao and it was a bipolar cap in the horizontal, this time the
> cap is good?
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
Panasonic Panasync/Pro5G (model TX-D1752) what resistor "R612"? Simoc Electronic Repair 2 07-06-2007 04:40 PM
sorry its a Panasonic Re: Panasonic tx28 tv fault help!!! paul405 Electronic Repair 0 12-01-2004 07:18 PM
panasync pro p110i clicks arjen Electronic Repair 0 09-04-2004 07:00 PM
Panasync S110 monitor schematic needed (chassis hv10s) Ray Electronic Repair 0 02-04-2004 08:50 PM
have a Panasonic Panasonic RS808 8 track player needs a new motor vze34x8m@incoming.verizon.net Electronic Repair 0 08-06-2003 09:18 PM
