Electronics Forums
Electronics Forums > Newsgroups > Electronics Newsgroups > Electronic Repair > Help me to identify this part
Reply
Thread Tools Display Modes
Bart Bervoets
Guest
Posts: n/a
      06-30-2006, 11:43 AM
From a tft monitor, AOC LM700
Part is on the mainboard and partly burned, numbers readable look
like this:
XM15AV
?596S
...O P+
Package is 5 pin smd IC
Board location ID U304
Any idea?
Bart Bervoets
Bart Bervoets
Guest
Posts: n/a
      06-30-2006, 12:14 PM
I have the feeling it could be a 5v regulator, digikey has a
LM2596S-5.0-ND in the list which points to 5V 3A regulator &
thermal limiter.
Would make sense on a mainboard but how sure can i be?
> XM15AV
> ?596S
> ..O P+
Would then be:
> XM15AV
LM2596S
5.O P+
As there's a 0 and no 3 i could exclude 3.3v and 12V
Making sense or am i missing the point here?
Bart Bervoets
jdgill@juno.com
Guest
Posts: n/a
      06-30-2006, 03:37 PM
Bart:
I'm working on an AOC TFT1560 monitor now. It has has a TO-220 case
5-pin
IC marked: LM2596S-5.0
It is a 150KHz 3A step-down power regulator used to convert the 12V
input to 5V for internal use.
My monitor is dead, although I can cause the backlight to turn-on,
there is no video image. Every once in a while, the monitor will
work OK, but be dead the next time I try it.
John
Bart Bervoets
Guest
Posts: n/a
      06-30-2006, 03:52 PM
Yep, seems my guess was right.
Thanks, and yes, mine is dead, that ic is burned.
I have a vibrant monitor as well with just a white screen.
No burned parts.
What should i check first?
Bart Bervoets
<(E-Mail Removed)> wrote in message
news:(E-Mail Removed) ups.com...
> Bart:
> 5-pin
> John
Eeyore
Guest
Posts: n/a
      06-30-2006, 06:42 PM
> No burned parts.
You just said that regulator chip is burnt. I'd sart by fixing that !
How old are these screens btw ? I recently heard that LCD monitors are
notoriously unreliable.
Graham
Bart Bervoets
Guest
Posts: n/a
      06-30-2006, 09:35 PM
No, that's another monitor, this one just shows blank, i'm stripping the
caps off
one by one and test with an esr meter.
Bart Bervoets
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
Need help to Identify a part please prolater Electronic Repair 1 06-14-2006 11:13 PM
Need Help to Identify a part please prolater Hobby Electronics 1 06-14-2006 02:19 PM
Help Identify Part Michael Kennedy Electronic Repair 9 03-28-2006 10:22 AM
Identify this part! pb Electronic Repair 4 07-20-2005 09:43 AM
Need help to identify a part not@home.com Electronic Basics 2 08-17-2003 07:10 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33
