Electronics Forums
Electronics Forums > Electronics Forums > Datasheets, Schematics, Manuals and Parts > Help Locating Relay
Reply
Thread Tools Display Modes
Help Locating Relay
Junior Member
      09-09-2011, 11:25 AM
Hello. I read the sticky at the top of the page and also googled this part to death and can't seem to find a supplier located in the US. I tried removing letters and numbers. Does anyone have any ideas? Thank you.
Senior Member
davelectronic's Avatar
      09-09-2011, 12:04 PM
Hi there. Whats the relay configaration ? is it latching or not ? i am in the uk, ok miles away, but there might be something over here the same, it will give more ideas. Dave.
Super Moderator
(*steve*)'s Avatar
Location: Mid way between Beijing and the the Ronne Ice Shelf (mind your projection) ...and don't call me Sir!
      09-09-2011, 12:21 PM
You're better off going to a site like digikey and searching for a similar device.
Here is the datasheet. (Yep, suppliers outside the US have valuable information too)
Armed with that you should have no problem finding something suitable.
There's plenty there. This one looks pretty good.
Junior Member
      09-09-2011, 02:34 PM
Thanks Steve, I ordered a couple to try them out.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
PLEASE HELP !! Toshiba 32ZD08B Stuck in Standby + Green Screen (help locating the Teletext module) Scott Electronic Repair 3 11-20-2004 01:57 PM
Help Identifying & Locating Parts Louis Bybee Electronic Basics 4 09-07-2004 05:57 PM
HELP locating sharp WD450 miniDV Video heads assy. at a reasonable price! Help Sharp WD450 miniDV cam video heads at a reasonable price.txt (01/01) Electronic Repair 1 06-08-2004 06:05 PM
Need help locating Bourns ECW1D encoder deftech General Electronics 0 09-19-2003 12:52 PM
Need help locating a small cheap LCD Chris Electronic Components 6 09-13-2003 06:42 PM
