Electronics Forums
Electronics Forums > Electronics Forums > Electronic Projects > Help with a lens power unit
Reply
Thread Tools Display Modes
Junior Member
      01-18-2010, 02:55 AM
Im new to the forum, and I am not very experienced with electronics, nor do I know really any terms and such.
But anyway, im building a better model of a power unit for a lens adapter system i build for video cameras. And this power unit is powering a 12mm vibrating pancake disk motor.
Basically the motor needs to be able to be run from 0.75-2.40v
This is because the voltage will need to be increased, to increase vibration, so I can use higher frame rates while shooting without detecting the vibration of the unit, but thats all camera techy stuff that doesn't really matter.
Anyway, so i want to have a rheostat with a control knob running out of the project box to control the voltage, and I also need to hook up some sort of battery level LED light indicator (voltage indicator). Also I want a on/off switch, and lastly I want to hook up a power input to charge the battery inside the unit, so I never have to open up the project box and I can plug the lens right into the charger and along with the battery level indicator, I can know when to charge it.
Ive built this before, but not with a rechargeable input plug and a battery level indicator and what not so thats what I cant figure out, also I need help with all the other parts, especially the rheostat, because I know I can find better, more applicable parts to use for the unit.
So anyway, I would really appreciate the help. If you guys could direct me to some links on the rheostat, battery lever indicator LED thinger, charging unit and parts, and what battery to use. And of course anything else you guys think I need to make this work.
But also, im not to experienced with how to hook this all up, like what order and where to solder what. So any help with that would be amazing as well!!!!
Thank you so much!!!
Junior Member
      01-18-2010, 02:56 AM
P.S. this is the vibrating motor i use that the power unit will be powering:
http://www.solarbotics.com/products/vpm2/
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
rec.models.rockets FAQ Part 02 - Names and Addresses rmrfaq@n2netmail.com Rocketry 0 11-26-2009 05:01 AM
cd lens scratching disk: adjust potentiometer? nah. J Electronic Components 3 01-07-2006 11:04 PM
Computer Power Usage paul Electronic Basics 6 05-11-2005 09:04 AM
Re: Wall-Warts Power Usage and Power Supplies Dantanna Electronic Basics 0 03-29-2005 04:04 AM
homemade power conditioner? Joe Electronic Components 44 05-04-2004 06:26 AM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93
