Electronics Forums
Electronics Forums > Newsgroups > Electronics Newsgroups > Electronic Basics > HELP!! Laser or active infrared as motion sensor ???
Reply
Thread Tools Display Modes
farha
Guest
Posts: n/a
      02-18-2006, 02:44 PM
I'm doing my project. here i hav 2 options. either to use the laser o
the active infrared as my motion sensor. well i'm quite in DILEMMA t
choose it. i'm considering the coat to construct the circuit and it
path range in sensing the motion. any expert in motion sensor
thanks p(^-^)
Chris
Guest
Posts: n/a
      02-19-2006, 02:13 AM
farha wrote:
> I'm doing my project. here i hav 2 options. either to use the laser or
> the active infrared as my motion sensor. well i'm quite in DILEMMA to
> choose it. i'm considering the coat to construct the circuit and its
> path range in sensing the motion. any expert in motion sensor?
> thanks p(^-^)q
Hi, Farha. There are always more than the two horns of the DILEMMA,
even if the third is just to do nothing.
However, I'd suggest you Google "PIR motion detector", and go from
there (and yes, the IR means infrared). These are usually used with
intrusion detectors in commercial security setups. The sensors
themselves aren't too expensive, either. You'll probably have a lower
total project cost with one of these, too.
Good luck
Chris
Christopher
Guest
Posts: n/a
      02-25-2006, 11:54 PM
Hello Farha,
On 18 Feb 2006 14:44:14 GMT, (E-Mail Removed)lid
My answers are from my low budget hobbyist perspective.
Is this used in the day or night or both. Indoors or Out.
Narrow field of view? What distance?
Ultra-sonic motion detection can be a good approach.
I agree with Chris (cfoely1064) that passive infrared methods are
probably easiest setup.
In your design do you want to use laser or active infrared for the
detection of a beam break, which would require opposite sending and
receiving side modules? This could give reasonable distance and
stability using a laser pointer type diode? This could work day or
night with certain alignment difficulties. Pulsing the beam can help
against false triggering used with a missing pulse detector circuit.
(555 type circuit)
The longest range of motion detection I have experimented with is
using Optical (phototransistor), which could detect the shift in
background changes in daylight. Distances of over 100 yards are easily
achievable. This was set up with a pinhole inside of a 12" tube, which
narrows down the field of view at a good distance.
Every method above has distinct advantages and major disadvantages.
I experiment with Theremins, which are the ultimate motion sensors
Good Luck, if you have not already finished your project.
RS Theremin
Christopher
Temecula CA.USA
http://www.oldtemecula.com
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
Active low or active high signalling? eem2am Microcontrollers and Programming 10 09-01-2012 05:24 AM
For Sale: Outdoor dual beams active infrared detector sealarm For Sale / Wanted 0 12-30-2011 02:20 PM
Active Infrared Motion Sensor dajpe@aol.com Electronic Design 1 07-11-2005 07:22 PM
Active HIGH / Active LOW muthusnv@rediffmail.com Misc Electronics 4 01-31-2005 11:18 PM
Is this IC active high or active low? Michael Electronic Basics 3 12-29-2003 06:11 PM
