Electronics Forums
Electronics Forums > Newsgroups > Electronics Newsgroups > Electronic Repair > Help fixing Mitsubishi TV model CK35304
Reply
Thread Tools Display Modes
rpesq@my-deja.com
Guest
Posts: n/a
      06-18-2006, 04:41 AM
Hi guys,
Need help to repair Mitsubishi console TV model CK35304. (36-inch,
manuf. date 1994).
Approx a month ago, when you would turn on the TV each day for the
first time, the top of the screen would be shrunk down a few inches.
As TV warmed up, the screen would return to normal. Color and clarity
of picture has been excellent throughout.
The other day, turned it on, just get a line thru the middle of the
tube. So, whatever was going bad, has definitely gone bad. I do not
have TV repair experience, but I have experience repairing other
high-voltage items, such as many Tube Guitar Amps, antique radios,
PC's, and even rebuilt a Video Game monitor once (installed a capacitor
kit). So I am familiar with the voltages involved.
I talked with a friend of mine who repairs TV (lives several hours away
from me...), and while he is hesitate to tell me a lot (he never tells
the secrets of the trade, so to speak...), he said that this a typical
problem with Mitsubishi TVs, and that the problem is probably in the
Vertical output circuit, then said 'maybe 5 capacitors, probably a
chip, and maybe a fuse'.
Here are some photos of the boards inside the set:
(mainboard)
http://mysite.verizon.net/cowman136/tv1.jpg
(closeup of area that may be the problem...)
http://mysite.verizon.net/cowman136/tv2.jpg
(power supply board)
http://mysite.verizon.net/cowman136/tv3.jpg
You guys can tell me whether my friends general advice is accurate or
not. For starters, I have proceeded assuming his advice was good, and
did some searches to try to narrow down what I am looking for.
Doing some Google searches based upon part numbers on the transistors
that I see on the mainboard (picture "tv2.jpg" above) , I found that
TA8427K is apparently my Vertical Deflector chip, that C2073 is
apparently my Vertical Output chip. In this circuit, I see the
following components (and checked them in-circuit, where noted:
- fuse (checks good)
- 15K ohm 3 watt resis. - checks good, approx 14K ohms in circuit
- 4700uF at 10V cap - did not test
- 2.7 ohm resistor - good
- 2700 ohm resis - good
- red capacitor approx 1 inch size with numbers (2A : 335K S) - value
unknown, not tested
- resistor with bands of "yellow - purple - gold - gold" - tests approx
4 ohms.
My photo tv1.jpg above highlights this area of the board. I do not see
any visibly burned components or exploded/leaking caps.
Assistance is MUCH appreciated. I really need to fix this myself, as
cash is very tight. I do not mind installing a few "extra" parts,
shotgun approach is fine. Also, advice as to where is best to buy the
parts (the IC's, as I probably have the caps & resistors) will be
appreciated. THANKS.
BJ
Inty XP
Guest
Posts: n/a
      06-18-2006, 07:36 AM
You have a vertical problem.
Hantarex ?
> (mainboard)
> unknown, not tested
> 4 ohms.
This resistor was good ! (yellow-purple-gold = 4,7 ohm)
Changing components without measures isn't a good idea.
Start from changing all electrolytic caps in that zone, then
> BJ
Inty.Evolution
(E-Mail Removed) -> per email normali e con immagini Jpeg
default
Guest
Posts: n/a
      06-25-2006, 04:24 PM
This is the flyback transformer area. If the design has the vertical
circuits power supplied by the flyback, then your height shrinkage could be
a premature sign the flyback is breaking down, or there could be a problem
only in the vertical circuit....changing all capacitors in the vertical
circuit is a common solution to certical problems, however the flyback xfmr
in that chassis is common fail\, so its of not it be mentioned.
Inty XP
Guest
Posts: n/a
      06-25-2006, 05:24 PM
> be
> problem
> xfmr
MAYBE a blown fuse resistor?
Inty.Evolution
rpesq@my-deja.com
Guest
Posts: n/a
      06-26-2006, 08:11 PM
Thanks to `Inty` and `default` for replies.
The fuses all check fine, unless I am not seeing all of them. I am
familiar with fuse-resistors, too.
Update: I changed the 3 electrolytics in the vertical circuits (100mfd
at approx 35V), and they did not help. I checked the caps that I
removed, and all were close to 100mfd (the weakest tested 88 mfd).
Talked to 2 guys (my original source, and another guy that I know who
was in the tv sales/service business for many years), and both guys
believe that 99% likelihood that the problem is defective TA8427K
vertical deflector chip. Both guys said this part goes bad regularly.
So I have already unsoldered it, and have ordered a replacement. Cheap
solution if it works. Less than $8 including postage for a real
Toshiba chip. Should arrive in a few days. If that does not fix it,
we'll go from there.
The only thing that I wonder about, is that my friend asked me to check
whether there is 24V from pin 6 to ground on TA8427K. Well, I got 0,
although it was `damn hard` to get a reading in that area of the board
while the set was operating. It is possible I was not getting good
contact with my meter. Assuming the 0 is accurate, he says that means
something else is wrong, although he feels that the chip is probably
bad also (which he originally said I should replace). So I Look around
on the board, there is not many components in that area. A diode goes
directly to pin 6 of TA8427K, and a bunch of other diodes are in the
immediate area (all diodes checked normal once I removed the TA8427K),
and of course the 100mfd caps (replaced), and a couple mica caps (very
unlikely to be defective). There is 1 glass fuse in the area, which is
good. He asked me to look for small black square boxes, which he says
would be fuses. There is none of them. I can easily identify the
components in the area, so I really cannot see any way that I am
missing a fuse anywhere. This might be a lot easier with a schematic,
but I doubt at this point it would tell me a whole lot.
I'll know more once the vertical deflector chip has been replaced.
Thanks again.
> > be
> > problem
> > xfmr
> Inty.Evolution
rpesq@my-deja.com
Guest
Posts: n/a
      06-30-2006, 02:03 AM
SOLVED by replacing the TA8427K vertical deflector chip. Good as new.
Thanks to everyone for their suggestions.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
help repairing Misubishi TV CK35304 Inverted colors lngroller Electronics Repair 0 01-27-2009 05:16 AM
Mitsubishi TV set (model ct-2531EPST) electrotech Electronic Repair 0 08-29-2007 03:35 PM
JVC I'Art TV : Model AV-32F702 : Opinions on fixing or replacing welcomed. Kazushi Electronic Repair 2 08-01-2006 02:44 AM
Mitsubishi Model XC3715C Need Schematic techforce Hobby Electronics 0 07-28-2005 09:58 PM
Mitsubishi 1992 model help Ken G. Electronic Repair 4 12-07-2003 06:36 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33
