Quote:
Originally Posted by morbe
Thanks every one.
This by no means is going to be a tube amp. Maybe one day i will make one. Right now im just taking baby steps. I feel a little bit more comfortable working with this ac adapter until i read that last post were it said 2000mA can start cardio problems and death it likely stuff. I guess what im getting out of this is, even though im messing with amps with pontential deadly levels, its more than likely not dangerous because the volts are not high enough to penetrate my body efficiently to kill me.
I would have loved to put an output transformer but i dont understan yet how it puts out electricity and how i could match it up to what i need from both devices. Plus this is my first project i didnt want to waste too much money. So far im in the whole about 50 bucks including both project parts and a book to learn as i go. This make shift amp will be in a chassis built from spare wood i have at my house. Power adapter was found and speaker is being donated.
Should i be worried that my guitars electronics are grounded and this power adapter is.not grounded. Most power adapters and plugs have a ground is that to protect me or the equipment.
But only at the right voltage. As davenn said, you need high voltage to break down the resistance in the skin. What this means is that anything below 50V with normal dry hands will do zero damage to yourself.
Also remember the golden rule of thumb, don't ever double dip. What this means is keep only one hand in harms way and the other far away. If you create a path across your heart for current to flow it is indeed worse then letting current flow from your left hand to your left foot. Or so they say, I know it has worked for me because I been hit by 240V before and it hurt like a bitch, but I am still here.
I have actually been shocked quite a lot. So don't let fear stand in your way, it only hurts for a second.
milliamps of current is what kills, but it needs high voltage to do the damage.
