Electronics Forums
Electronics Forums > Electronics Forums > Circuit Help > heat control for 230v 30w soldering iron
Reply
Thread Tools Display Modes
Junior Member
      11-02-2009, 02:56 AM
Any ideas for a (cheap) heat control for 230v 30w soldering iron?
Super Moderator
      11-02-2009, 10:03 AM
A triac light dimmer, an old heating blanket regulator, or simply a diode in series to cut power in half?
Junior Member
      11-02-2009, 07:34 PM
Thanks for that, Resqueline. Light dimmer around $80 - I'd explored that but I'm on a lean pension. Daren't steal my wife's electric blanket. May come down to a diode but I'd prefer something variable ......
Super Moderator
      11-02-2009, 09:17 PM
Ok, I see dimmers are as overpriced in your place as they are at mine. They really shouldn't be that costly as they are very simple devices. Lacking a well-stocked scrap-parts-bin you could still build a dimmer yourself for around a tenth of that price, or you might find one cheap on ebay. If those are not viable options you could put some bulb(s) in series with the iron to get more power steps.
Junior Member
      11-02-2009, 10:09 PM
Thanks again Resqueline - currently searching for a xfmr I'm sure I had .....
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
Cold Heat Soldering Iron (Does it work?) John Miller Electronic Components 5 07-07-2004 04:39 PM
Advice on soldering iron please... Odie Ferrous Electronic Basics 7 06-11-2004 04:24 PM
recomendations for soldering iron for smd & through hole components krem Electronic Basics 10 04-15-2004 03:45 PM
recomendations for soldering iron for smd & through hole components krem Electronic Components 11 04-15-2004 03:45 PM
The Red Planet approaches. Paul Burridge Electronic Design 74 09-06-2003 02:08 AM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93
